Violating the law of conservation of energy
The discussion revolves around the conservation of energy during a change in the radius of a rotating body. It explains that while the angular momentum remains constant, the moment of inertia changes, leading to a new angular velocity. The calculations suggest that the new energy can be either greater or less than the initial energy, depending on the factor k. However, it is clarified that work is required to change the radius, which affects energy conservation. The conversation concludes with an acknowledgment that asking questions is important for understanding complex concepts.
deep838
I know that's impossible, so please help me!
Let there be a body rotating about its axis, with a moment of inertia I and an angular velcity w.
The angular momentum of the system is L = Iw.
Now, if the radius of the body change, its moment of inertia will also change. Let the new moment of inertia be I`, such that, I`= kI.
But the angular momentum of the system will remain constant.
So, the angular velcity must change. So, w`=w/k.
But, initially, the energy of the system was purely kinetic and was given by
E=1/2 Iw2.
The new energy is given by, I`= 1/2 I`w`2 = 1/2 kI (w/k)2
So, E`= E/k.
So the new energy of the system is either more {0<k<1} of less {k>1} than the previous energy!
What am I doing wrong?
You need to do work to change the radius. Imagine whirling a ball on a string around. If takes work to pull in the ball.
ok...got it... so silly of me to even ask this.
The only silly question is the one you don't ask.
hmm... who said that?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
