Why Does Voltage Source Droop/Sag?
In summary, a non-ideal voltage source will experience a voltage drop when the current draw of the load increases due to the presence of a small but non-zero series resistance. This can be better understood by considering series circuits and voltage dividers.
EENoob
Dear Forum,
Hello all, this is my first post. I'm trying to teach myself EE enough to design basic circuits and play with microcontrollers (my background is computers, programing, and, um, music). I've started reading The Art of Electronics and many Internet sources but I seem to be missing something fundamental. I'm hoping that someone can point me in the right direction.
If V = IR (Ohm's law) then why does the voltage from a non-ideal voltage source droop/sag when then current draw of the load increases? Such as the fairly generic linked graph shows:
http://en.wikipedia.org/wiki/File:Droop_behaviour.png"
Thank you very much in advance,
Noob
Hello,
Well you need to understand series circuits and perhaps voltage dividers.
An ideal voltage source has zero output resistance in series with it.
All real non-ideal sources have some small but non zero series resistance.
Let us suppose we start with a real 100 volt source which has a 1ohm series output resistance.
We model this by an ideal source of 100v in series with 1 ohm.
Let us connect a variable 99 ohm resistor to it. So the total resistance seen by the ideal source is 100 ohms.
99 volts appear across the load and 1 volt is dropped across the series resistor. (V=IR in both cases)
As we reduce the load resistor to increase the current draw, the ideal voltage stays at 100volts and its series resitance stays at 1 ohm. When the load resistance has been reduced to say 49 ohms the total reistanc seen by the ideal source is now 50 ohms and the current 2 amps.
So 2 volts is now dropped across the series 1ohm resistance and 98 volts across the load resistance (again V=IR in both cases)
Reduce the load reistance still further to 1 ohm and the current increases to 100/2 amps.
50 volts is now dropped across the series resistor and only 50 volts across the load.
So the voltage, as seen by the load, has drooped from 99 volts to 50 volts in this example.
The values quoted are extreme for demonstration. Normal series resistances of power supplies are normally measured in milli or even micro ohms.
1. Why does voltage source droop/sag?
Voltage source droop or sag is caused by various factors such as high load currents, long wire lengths, and resistance in the circuit. These factors result in voltage drops along the circuit, leading to a decrease in voltage at the load.
2. How does high load current affect voltage source droop/sag?
High load currents cause an increase in resistance, which then leads to a voltage drop along the circuit. This voltage drop results in a decrease in voltage at the load, causing droop or sag.
3. Can voltage source droop/sag be prevented?
Voltage source droop/sag can be prevented by using thicker wires with lower resistance, reducing the load current, and minimizing the length of the circuit. Additionally, using voltage regulators or stabilizers can also help maintain a constant voltage at the load.
4. How does resistance in the circuit affect voltage source droop/sag?
The resistance in the circuit causes a voltage drop, which leads to voltage source droop/sag. The higher the resistance, the greater the voltage drop, resulting in a more significant decrease in voltage at the load.
5. What are some common applications of voltage source droop/sag compensation?
Voltage source droop/sag compensation is commonly used in power supply circuits, where a constant voltage is required for sensitive electronic components. It is also used in electric power transmission systems to maintain a stable voltage across long distances. Additionally, voltage source droop/sag compensation is essential in renewable energy systems to ensure a steady power output.
  • Electrical Engineering
10K
11K
  • Electromagnetism
