Voltage Follower Circuit Design: Input Too Low?
  • Thread starter Thread starter cupidsd
    Voltage
The discussion centers on designing a voltage follower circuit with a low input voltage of 0.8 - 0.9V, where the output unexpectedly measures around 1.4V. Participants suggest that the issue may stem from the op-amp's requirements for a DC path to ground and the need for sufficient headroom between the input signal and supply rails. Recommendations include adding a resistor from the non-inverting input to ground and using an LM324 op-amp for better performance. Additionally, measuring the input and output simultaneously and using an oscilloscope to check for AC components are advised to diagnose the problem. The conversation highlights the importance of understanding op-amp specifications and circuit design for accurate voltage following.
cupidsd
hi all,
I am trying to design a voltage follower circuit. The input is quite low, around 0.8 - 0.9V.
I tried an OP, whose power supply is +/-16V, then connected the output with inverting-input, and connected the non-inverting-input with my input (0.8 - 0.9V). But the output does not follow the input, and actually the output is around 1.4+V.
The circuit does not work well. I guess it is due to the input is too low. Am I right? So what OP should I use then? Any comment is welcome.
Thanks a lot.
That is a classic circuit and usually works OK. Small signals don't matter.
Some opamps require some DC path to ground from the input pins, so you could try a 100 K resistor from the non inverting input to ground. (The common of your two supplies could be called a ground.)
This is specified in the data sheets of the opamp or you can just look at the schematic diagram of the opamp's insides and look for open circuited bases on the input transistors. These have to have DC current flowing into them for the transistors to work.
Another test is to measure the input and output simultaneously. If they are the same, then the opamp is working properly. In your case, if the input is actually 1.4 volts when it should be 0.9 volts, then you need to work out why this is the case.
Electrolytic and Tantalum capacitors are pretty leaky and this can disturb high impedance circuits.
It would also be worth looking at the output with an oscilloscope. What measures as a small DC voltage on a DC meter could actually be quite a large AC voltage that happens to average as a small DC voltage
You said +/- 16 volts.
Are there three leads on the supply, + - and common?
or just two?
Most opamps need "headroom" between signal and supply rails. 1.4 volts sounds like 741's common mode limit.
Try a LM324.
I can picture a voltage follower op amp...V+ = V-...I get that. Vin = Vout.
The obvious question is why do you need the voltage follower? Why not just hook your original voltage source to your load?
Is the op-amp in this case perhaps allowing more power while maintaining the same voltage? In other words...is the op amp capable of delivering more amps in this case?
Also, check the pins of the opamp chip to see if it has offset control.
This is simple to use and may give the effect you are having if it is not connected.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
