Voltage Multiplier: Increasing 1.5V to 5V
To increase the voltage from a 1.5V battery to power a small car, using a circuit from a disposable camera may not be effective, as it typically produces high voltage with low current for short durations. The discussion emphasizes that simply boosting voltage won't solve power requirements, as power output remains constant; thus, using a 1.5V motor is recommended. Concerns about gearing and weight are highlighted as more critical factors for performance than voltage multiplication. Suggestions include using low-loss gearing systems and exploring alternative battery types for better efficiency. The conversation ultimately advocates for sticking with the 1.5V battery while optimizing other aspects of the project.
Thewayne45
I was wondering if anyone know how to take the circuit from a throw away camera and make it increase the voltage in a 1.5V battery. I'm building a car right now and as u probably know 1.5V isn't enough to run it and I'm trying to get it too at least 5v.
wayne - you need more than just 5V, you need some power (voltage and current) to move a little car.
the circuit for driving a flash might very well increase the voltage to 100V or more, but it will have only a small amount of current and for a VERY SHORT period of time.
why not just use a 9V battery or 4 AA batteries?
Cliff
Thanks for responding cliff but it's a project for school and we are only allowed to use a 1.5V batery to: Make the car go up a 10 and 25 degree ramp with a trailer that has wight in it, and have working head lights. All this has to be run off of a 1.5V battery.
How much weight are we talking about? I think you should be more concerned over the gearing and the weight of the car than trying to double or triple the voltage. The power output is always going to be the same no matter if have a voltage multiplier. Remember P=IV and V=IR. If the resistance is constant and you double the voltage, the current is reduced by the same magnitude. Also when you introduce more circuitry you are going to end up wasting energy in the process. Just stick wih the 1.5V battery and use a 1.5V DC motor. You can get one here (http://scientificsonline.com/product.asp_Q_pn_E_3037590), your local hobby store or radio shack.
^ Agreed.
LEDs too.
An o-ring as a belt might be an idea for a low-loss gearing system too.
Cliff
Years ago I used a batery contained in a Polaroid film pack to power a small motor for my son's grade school project; to demonstrate perpetual motion, a scam but he fessed up. Unfortunately I cannot recall its voltage, but I think it was 1 1/2volt. It was about 2" X 3.5", and perhaps 1/32" in thickness. I believe I cut it to size with a scissors, but it's been so long I hardly remember. I used it because it was easy to hide. But it turned out to have a good deal of punch compared to the carbon-zinc battery of the day. I don't know if the energy would be comparable to a modern exotic metal battery, but it may have a greater reactive surface area, lesser internal impedance, and a weight advantage. Might be worth investigating if they're still being made.
As an aside, I also used the sonic focusing circuitry of a cheap Polariod camera in another of his projects.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
