Does a capacitor delay the voltage from a voltage source in a circuit?
In a circuit with a capacitor, the voltage supplied by the voltage source is not delayed; the capacitor's voltage lags the current by 90 degrees. When the voltage source is sinusoidal, the current through the capacitor leads the capacitor voltage by 90 degrees, while the current through the resistor is in phase with the voltage supply. The discussion clarifies that the capacitor experiences the voltage from the source directly, without delay. The terms "inductor current" were mistakenly used, as the focus is on the capacitor and resistor behavior. Overall, the current relationships in the circuit are consistent with established electrical principles.
JustStudying
If we have a circuit (see attached)
will our voltage source's supplied voltage be delayed by the capacitor in anyway?
(as the voltage across a capacitor lags the current through a capacitor by 90 degrees)
then, as the resistor,voltage source, and capacitor are all in parallel does this
cause the voltage source to end up supplying a 'lagging' voltage (due to the capacitor's characteristics)?
OR is the capacitor forced to experience whatever the voltage source is supplying?
(therefore causing the inductor current to lead the capacitor by 90 deg)
That's it. We assume that the voltage source is able to do what it is supposed to, regardless of what is going on in the circuit. And you are right, the current will lead the voltage by 90 degrees.
Likes 1 person
Inductor? Resistor? What is it?
Resistor current lags the capacitor current by 90°.
Right.
What inductor current? What inductor?
EDIT:
If the voltage source is dc: for the capacitor, i = C dV(t)/dt. Since dV(t)/dt is infinitely large (going from 0 to V in zero time), the current is infinite for an infinitely short time.
Mathematically, V(t) = V U(t), the unit step function, and i(t) = CV δ(t) where δ(t) is the Dirac delta function with dimension T-1.
If the source is a sinusoid, which it just dawned on me it probably is, then yes, the current will lead the voltage by 90 deg. and its magnitude is wCV, w = 2 pi f.
Likes 1 person
@NascentOxygen agreed. and when he says "inductor current", I was assuming he just meant current through the voltage source. Although "inductor current" is a term I have not heard before in this context...
@rude man - From the OP, I would guess that he/she is supposed to assume sinusoidal voltage
Yesd, that just dawned on me. Thanks.
sorry! i meant the capacitor current when i said 'inductor current' - got mixed up reading my notes over and over, thanks guys!
So in this case, the current through the resistor should be in phase with the voltage supply, while the current through the capacitor leads the capacitor voltage by 90 deg am I correct?
You now realize you are really stating nothing new. "The current through the resistor is always in phase with the voltage across that resistor", while "the current through the capacitor always leads the capacitor voltage by 90 deg". :smile:
yep. you got it.
  • · Replies 21 ·
