Voltmeter reading in a parallel circuit with two batteries
7 replies · 4K views · last reply
moenste
In the circuit below the batteries have negligible internal resistance and the voltmeter V has a very high resistance. What would be the reading of the voltmeter?
Circuit schematic of two branches joined in parallel by a voltmeter V: left branch has a 10 V battery in series with a 1.0 Ω resistor, right branch has an 8.0 V battery in series with a 4.0 Ω resistor.
Answer: 9.6 V.
2. The attempt at a solution
I used the Kirchhoff's rule: the current that flows from 10 V is I1, current that flows to the voltmeter is (I1 - I3) and the current that flows into the 8 V is I3. So I got 10 - 8 = 4 I3 + 1 I1 and 10 = RV (I1 - I3) + 1 I1. But this doesn't look like it can be solved. We have R which I don't what to do with it. Any ideas please?
The voltmeter has a high resistance (ideally infinite resistance) so it passes no current. What does that tell you about the relationship between ##I_1## and ##I_3##?
That I1 - I3 = 0?
I also calculated: I = V / R = 10 / 1 = 10 A and so V1 = 10 * 1 = 10 V and I = 8 / 4 = 2 A, so V2 = 8 V.
moenste said:
That I1 - I3 = 0?
Sure, or in other words, ##I_1 = I_3##. So there's really only one current:
Circuit schematic with two series branches, one with a 10 V battery and 1.0 Ω resistor, the other with an 8.0 V battery and 4.0 Ω resistor, joined by a central branch containing a voltmeter labelled V; a blue loop with arrow shows current I circulating around the outer loop.
No, you need to take the entire loop into consideration in order to determine the current. Write KVL around the loop and solve for the current.
Don't we get 10 - 8 = 4 * I + 1 * I → 2 = 5 * I → I = 0.4 A?
Looks good.
gneill said:
Looks good.
And then we have V = I R + 0.4 * 1 = 0.4 V or 0.4 * 4 = 1.6 V. And then either 10 - 0.4 = 9.6 V or 8 + 1.6 = 9.6 V. Should be correct.
