Volume of Region Bounded by Given Planes
  • Thread starter Thread starter alalall2
    Planes Volume
alalall2
(1 pt) Find the volume of the region bounded by the planes
V = ∫∫7/4-6/4y-2/4x
Since y=x I found their values when z = 0.
6x+2x=7, x=7/8
y= 7/8 is the maximum value y will have in this integration as it decreases as x approaches its maximum value: 2x = 7, x=7/2.
When I made a 2-D image of the region I would be integrating on I came up with a triangle which had two areas that needed to be integrated separately as in the first region: 0≤x≤7/8 and 0≤y≤x, and in the second region: 7/8≤x≤7/2 and 0≤y≤(7/6 - x/3).
After integrating my result was 0.893229167.
What I am wondering is if I am using the correct limits for my integration or if I made a mistake in my math.
I would avoid double integral thus: a horizontal cross-section of the region is bounded by the x and y axes and the line
2x+6y = 7-4z
The area of that right angle triangle is \frac{(7-4z)^2}{24} for z in[0,\frac{7}{4}].
The definite integral should be \frac{7^3}{12\cdot 24}=1.19
The system still thinks that is an incorrect answer
Could the system be expecting a different format than what you entered, such as different number of decimal places?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
