Volume of Pyramid: 28370.082 m3
  • Thread starter Thread starter movsesinator1
    Volume
The volume of the pyramid, based on a base area of 20.4 acres and a height of 69 ft, was calculated to be approximately 28,370.082 m³ after conversion. The formula used was V = (1/3)bh, where the base area in square feet was converted to cubic meters. There was some confusion regarding the correct base area conversion, but the final volume was confirmed. Participants emphasized the importance of showing all steps in calculations to avoid errors. The discussion concluded with the acknowledgment of the simplicity of the problem once the correct approach was taken.
movsesinator1
The base of a pyramid covers an area of 20.4 acres (1 acre = 43, 560 ft^2) and has a
height of 69 ft.
Find the volume of this pyramid in cubic meters. Answer in units of m3.
V of Pyramid= (1/3)bh
where 'b' is 43,560 ft^2
My attempt at the solution got me 28370.082 cubic meters after converting.
Don't you mean b= 43,561*20.4 ft2?
Also how many m= 1 ft?
Yes that's what i meant. I just redid my solution. Several figures off lol. But please, attempt the problem so i can check my answer
might i add that the question wants the answer in sigfigs
also about the conversions. let's just find the answer in cubic feet first. the conversion can be done afterwards
I was asking because I didn't know.
V=1/3*20.4*43560*69
and according to google 1ft2=0.0283168466 m3
so I get 578,749.7m3
thanks that's what i got. this problem was extremely simple i was just exhausted and tried skipping steps foolishly.
guess its time to close this thread
