Volume enclosed by two spheres using spherical coordinates
The discussion focuses on calculating the volume between two spheres using spherical coordinates. The first sphere has a radius of 2 centered at the origin, while the second is also a radius of 2 but centered at (0,0,2). The correct volume is found by setting up two integrals based on the intersection angle of the spheres, determined to be at φ = π/3, leading to the answer of 10π/3. Participants clarify the need for proper bounds and the implications of changing the order of integration, concluding that the suggested change may complicate the problem unnecessarily. Understanding the region between the spheres is crucial for setting up the integrals correctly.
Forcefedglas
Use spherical coordinates to find the volume of the solid enclosed between the spheres $$x^2+y^2+z^2=4$$ and $$x^2+y^2+z^2=4z$$
$$z=\rho cos\phi$$ $$\rho^2=x^2+y^2+z^2$$ $$dxdydz = \rho^2sin\phi d\rho d\phi d\theta$$
The first sphere is a sphere of radius 2 centered at the origin, and the second is a sphere of radius 2 centered at (0,0,2). So I tried setting the up the triple integral as $$\int_{0}^{2\pi}\int_{0}^{\pi/2}\int_{4cos\phi}^{2} \rho^2sin\phi d\rho d\phi d\theta$$
Which gives me a negative answer. I'm guessing my bounds for phi or rho are off?
Additionally, the question suggests I use the iterated order $$d\phi d\rho d\theta$$ but I'm unsure how to change the iterated order around like it suggests. Any help would be appreciated, thanks!
First you need to specify exactly what region you are describing as "between" the spheres. In the cross section below, is the the blue or the green region?
In either case the limits depend on the ##\phi## value where the curves intersect. If it's the blue region you can go from ##\rho_{inner}## to ##\rho_{outer}##. If it is the green region you have to break it into two integrals depending on whether the ##\rho## radius is above or below the intersection point.
BvU said:
You chose mathematician's spherical coordinates ?:) ! (:smile:)
Can you explain the ##4\cos\phi## to me ?
##x^2+y^2+z^2=4z##, so ##\rho^2=4\rho cos\phi##
In either case the limits depend on the ##\phi## value where the curves intersect. If its the blue region you can go from ##\rho_{inner}## to ##\rho_{outer}##. If it is the green region you have to break it into two integrals depending on whether the ##\rho## radius is above or below the intersection point.
I've typed exactly what the question asked so the question itself doesn't exactly specify, but I assumed it was the green section. The answer is ##10\pi/3## if that's any help.
Well, the answer of ##\frac{10\pi} 3## is consistent with the green region. To help you understand the problem, put your pencil on the origin in the picture. That is where ##\rho = 0##. Now move your pencil in the radial (##\rho##) direction across the green area. Which circle does it hit? Do you see that which circle it hits depends on whether you headed above or below the ##\rho## line I drew? That's why you need two integrals. In each ##\rho## goes from ##0## to the circle it hits. The limits on ##\phi## depend on whether you are above or below the angle I show in the diagram. So set those two integrals up and show us what you get.
well, if ##\phi = 0## then ## \rho = 4## seems a strange lower bound to me...
Yeah I know something's off with my bounds but I'm not sure how to get the correct bounds in this case; or how to switch around the iterated order like the question suggests.
Ah ok I think I understand now, I found the angle of intersection by setting ##4cos\phi=2##, giving ##\phi=\pi/3## , so the integral becomes ##\int_{0}^{2\pi}\int_{0}^{\pi/3}\int_{0}^{2} \rho^2sin\phi d\rho d\phi\ d\theta + \int_{0}^{2\pi} \int_{\pi/3}^{\pi/2} \int_{0}^{4cos\phi} \rho^2sin\phi d\rho d\phi d\theta ##, and evaluating this gives ##10\pi/3##. One last question though, the question suggested that I change the iterated order to ##d\phi d\rho d\theta##, how would I do this and how would this simplify the problem?
Forcefedglas said:
Ah ok I think I understand now, I found the angle of intersecion by setting ##4cos\phi=2##, giving ##\phi=\pi/3## , so the integral becomes ##\int_0^{2\pi}\int_0^{\pi/3}\int_0^2 \rho^2sin\phi d\rho d\phi\ d\theta + \int_0^{2\pi}\int_{\pi/3}^{\pi/2}\int_0^{4\cos\phi} \rho^2sin\phi d\rho d\phi d\theta ##, and evaluating this gives ##\pi/3##. One last question though, the question suggested that I change the iterated order to ##d\phi d\rho d\theta##, how would I do this and how would this simplify the problem?
I fixed your misplaced braces. You should get the correct answer now.
There is no point in switching the order of integration. And putting the ##\phi## before the ##\rho## integration is a bad idea because as it is, it's easy to solve for ##\rho## in terms of ##\phi##. To reverse the order you will get an inverse cosine in there. Not simpler.
Oh ok, strange that the question suggested for me to do so then. Either way, thanks for all the help.
  • · Replies 34 ·
