Sketching Region R Bounded by Curves: A Homework Problem
In summary, you use the cylindrical shells method to solve for ##A##. You then use the disc method to solve for ##v##. Lastly, you use the shell method to solve for ##h##.
Jimbo57
96
Sketch the region R bounded by the curves y = x, x = 2 - y^2 and y = 0.
This is the initial part of an integral problem and I'm just curious about the method here.
So, would it be proper to take the x = 2 - y^2 function and write it in terms of y as the dependent variable? ie, y = sqrt(2-x)
I believe the graph looks the same but for setting up the integral, would it change anything?
Thanks!
Jim
You should sketch out ##x=2-y^2## just to be on the safe side.
i.e. ... what happens to x for negative values of y?
In ##y=\sqrt{2-x}## can y ever be negative?
If x > 2, y is imaginary - but in the original form, x cannot be bigger than 2.
When you change over like that these are things you have to think about.
It may not matter this time, since your other bound is y=x - but note that it is easier to change that one to x=y.
I suspect the objective is to find an area - in which case it is reasonable to change to any representation that has the same area and a good idea if it gives you easier math. I don't think the surd does that for you, but swapping the roles of x and y will ... just do ##\int f(y)dy##.
Put it another way - is the area enclosed by x=2-y^2 and y=x the same as the area enclosed by y=2-x^2 and x=y?
Yep, I see exactly what you're talking about. One is a horizontal parabola and the other is just half of one. I redid my work, keeping it in the original form. It actually made it seem easier too. Any chance you could proof my work Simon, or anyone else? Thanks for your help btw!
The second part says: Indicate the method you use to set up the integrals (do not integrate) that give the volume of the solid generated by rotating the region R around:
i: the x-axis
ii: the y-axis
iii: the line x = -2
iv: the line y = 1
For i:
Using cylindrical shells,
C = 2∏y
A = 2∏y((2-y2) - y)
v = 2∏∫(2y-y3-y2)dy for y = [0,1]
For ii:
Using the disc method,
A = ∏(2-y2)2 - y2)
v = ∏∫(2-y2)2 - y2)dy for y = [0,1]
for iii,
A = ∏((2-y2 + 2)2 - (y+2)2)
V = ∏∫((4-y2)2 - (y+2)2)dy for y = [0,1]
for iv,
Using shells,
Same as i:
C = 2∏y
A = 2∏y((2-y2) - y)
When you get over the idea that the x and y-axis have to have a particular use, it does often get easier.
I will advise you to learn LaTeX for writing equations ;)
Your approach appears to be that of applying definitions and equations.
That's not how I would construct an integral - but you know your course.
The bounded region is the positive part of the parabola with a wedge-thing cut out of it.
For 1 - shell method check.
##x=y## intersects ##x=2-y^2## at (x,y)=(1,1)
##x=2-y^2## intersects ##y=0## at (x,y)=(2,0)
so 0<y<1 and 0<x<2.
a shell radius ##y##, thickness ##dy## and height ##h(y)## has volume ##dV=2\pi y h(y) dy##
##h=x_2-x_1## is bounded above by ##x_2=2-y^2## and below by ##x_1=y##
##\Rightarrow h(y) = 2-y^2 - y##
so the volume is $$V=2\pi \int_0^1 y(2-y^2-y)\; dy$$
Looks like what you have ... notice how I have more detail about how I got things.
Likes 1 person
1. What is the purpose of sketching region R bounded by curves?
The purpose of sketching region R bounded by curves is to visualize the boundaries and shape of the region in question. This can help in solving problems related to calculating area, volume, and other geometric properties of the region.
2. What are some common types of curves that can bound region R?
Some common types of curves that can bound region R include lines, parabolas, circles, ellipses, and hyperbolas. These curves can be both straight or curved.
3. How do you determine the boundaries of region R when sketching?
The boundaries of region R can be determined by finding the points of intersection between the curves that bound the region. These points can be found by setting the equations of the curves equal to each other and solving for the variables.
4. Can region R be bounded by more than two curves?
Yes, region R can be bounded by more than two curves. In fact, it is common for regions to have multiple boundaries formed by several curves. In such cases, it is important to carefully identify and plot all the curves to accurately sketch the region.
5. Are there any key strategies or tips for sketching region R bounded by curves?
One key strategy for sketching region R is to start by plotting the curves individually and then identifying their points of intersection. Another tip is to label the axes and mark the scale to ensure the accuracy of the sketch. It is also helpful to use different colors or shading to differentiate between the curves and the region itself.
