Volume of a solid in first quadrant
  • Thread starter Thread starter Ashford
    Solid Volume
Ashford
Find the volume of the solid whose base is the region in the first quadrant bounded by the curves y=x^2 and y=x, and whose cross sections perpendicular to the x-axis are squares.
No idea what to do here
Start by drawing a graph of the region. Then draw a sketch of the solid object.
Ok, I've done that but I still don't know which equation to use and how to set it up.
Your typical volume element has a base that extends from y = x^2 up to y = x, has the same height, and is \Delta x wide. Your limits of integration are the values of x where the two curves intersect.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
