Vortex Breakdown: Significance in Airplane Design
  • Thread starter Thread starter aerobilal
    Vortex
Vortex breakdown refers to the time it takes for vortices generated by an aircraft's wings to dissipate after passing through the air. This phenomenon can lead to severe turbulence for following aircraft if they enter the same airspace before the vortices have settled. It is particularly significant in airplane design, especially for delta wings, where the behavior of vortices is influenced by the Reynolds number. Understanding vortex shedding and breakdown is crucial for air traffic control, as it dictates spacing between aircraft during takeoff to ensure safety. The discussion highlights the importance of managing vortex interactions to prevent turbulence-related incidents.
aerobilal
does anyone know what's breakdown of a vortex. what is its significance in airplane design?
<background vortex information>
When fluid flows over an aerofoil as with air over an aeroplane's wings, a phenomenon known as vortex shedding occurs. This can be observed (in a wind tunnel) as a series of vortices coming off the trailing edge of the wing. A vortex will appear in a clockwise direction from the upper surface, then in an anticlockwise direction from the lower surface, and this cycle repeats itself. Vortex shedding caused the failure of the famous Tacoma Narrows bridge, - the frequency of vortex shedding matched the natural frequency of the bridge.
</background info>
Now, to answer your question. The issue of "vortex breakdown" involves the amount of time it takes for these vortices to settle down after an aircraft has passed through the air. If another aircraft passes through the same air before the vortices have subsided the following aircraft can experience severe turbulations. This is the reason that ATC allow a set time between aircraft taking off on the same runway (and not for collision avoidance!).
i guess you are confused between vortex wake and wing tip vortex. what i was asking is the "vortex breakdouwn(burst)" phenomenon on delta wings which is dictated by reynold number.
Ah, vortex burst, sorry, was confused by the term "breakdown".
Perhaps this link may prove useful:
http://www.sv.vt.edu/classes/ESM4714/Student_Proj/class93/schaeffl/vortex.html
thanx it is useful
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
