coverband
- 171
- 1
Consider an imaginary circular disc, of radius R, whose arbitrary orientation is described by the unit vector, [tex] \vec {n} [/tex], perpendicular to the plane of the disc. Define the component, in the direction [tex] \vec {n} [/tex], of the angular velocity, [tex] \vec {\Omega} [/tex], at a point in the fluid by [tex] \vec {\Omega}. \vec {n} = \lim_{R \rightarrow 0}[\frac {1}{2 \pi R^2} \oint_C \vec {u}.dl] [/tex], where C denotes the the boundary (rim) of the disc. Use Stokes' theorem, and the arbitrariness of [tex] \vec {n} [/tex], to show that [tex] \vec {\Omega}= \frac {1}{2} \vec {\omega}[/tex], where [tex] \vec {\omega} = \nabla * \vec {u} [/tex] is the vorticity of the fluid at R=0. [This definition is based on a description applicable to the rotation of solid bodies. Confirm this by considering [tex] \vec {u} = \vec {U} + \vec {\Omega}* \vec{r} [/tex], where [tex] \vec {U} [/tex] is the translational velocity of the body, [tex] \vec {\Omega} [/tex] is its angular velocity and [tex] \vec {r} [/tex] is the position vector of a point relative to a point on the axis of rotation.]
Stokes' theorem : [tex] \oint_c u.dl = \iint_S (\nabla * u) .n ds [/tex]
Answer it gives in back of book is:
Stokes theorem gives
[tex]\oint_c u.dl = \iint_S (\nabla * u) .n ds = (\omega.n)\pi a^2 [/tex] (How did they get this !?)so [tex] \Omega.n = \frac {1}{2} \omega . n[/tex]; but n is arbitrary so [tex] \Omega = \frac {1}{2} \omega. [/tex] NB [tex]\oint_c u.dl = \oint_c U.dl + \oint_c (\Omega * r).dl = \Omega.\oint_c (r*dl) = \Omega.n \int_{0}^{2\pi} a^2 d\theta [/tex]
