Want to find out the mass movement capability of my motor
To determine the mass a motor can drive, the key specifications include a torque of 5 Nm and a wheel radius of 0.05 m, suggesting it can theoretically lift around 10 kg. The motor operates at 90 rpm, which may indicate it is designed for specific applications like car windows, and its performance could be affected by load conditions. Calculating the force at the wheel's edge shows it can exert 100 N, equating to a lifting capability of 10 kg under ideal circumstances. However, real-world factors such as efficiency and potential current draw under load must be considered, with estimates suggesting a power output of about 47W. Overall, while the motor appears capable of lifting 10 kg, caution is advised regarding load limits to prevent overheating or damage.
SOA
am not sure if i am asking it right, it appears to be very easy, but am un able to solve it...
any help is highly appreciated..:)
Ques: ihave a motor wuth these specs
torque = 5 Nm
no of revolution = 90 rpm
radius of wheel mounted on motor shaft = 0.05 m
i need to calculate the mass which this motor can drive?
A constant torque of 5N turns the wheel at a constant 90rpm means there is friction in the system balancing it out. No net torque.
But if you put a Newtonmeter on the rim and figure the force to stop it, then you also have the maximum weight it can hold.
Does this motor have a gear box in it? 90rpm seems very slow for an off-load speed. What sort of motor is it?
yea i will mount it on some wheel definitely but before that i want to get the idea of its capability...
yea it is worm geared motor... mostly used in car windows.
iirc there are important real-life restrictions - don't rl electric motors draw more current under load or something? I remember something about motors burning out.
But doing stuff with motors is usually more about power than work.
So you need to settle on something for a benchmark.
Manufacturer usually has a clue or three too.
A naive calculation would suggest to expect it to hold 10kg against gravity with the specs shown. I wouldn't bet on it though. The RPM given, if stamped on the motor, may be that under normal load (eg - lifting a window). Have you run it without yet?
From the data, it looks as though the motor will produce a force of 100N at the periphery of the 0.05m wheel. That suggests it should lift 10kg if you use it as a winch, for instance.
Torque = Force times radius
so Force = Torque/ radius
There is another important parameter and that is the useful Power output.
The power out will be Torque times angular speed (in radians)
That's 5 * 90*2π/60 = 47W
If the motor is 50% efficient, that means a current draw of about 8A, when running on full spec load. Doesn't sound too far wrong for a chunky bit of car electrics.
The motor should lift this 10kg at about 0.5m/s.
Someone else might like to check these shirt cuff sums.
[edit - well, at least Simon agrees with my 10kg figure. Ain't sums wonderful?
and the bit about being careful not to overload is relevant too.]
