WANTED: Formula for frictional resistance
The discussion revolves around finding the formula for calculating frictional resistance in a hydraulics lift system. A specific scenario is presented involving a ram and cylinder with given dimensions, oil viscosity, and ram travel speed. The proposed formula for resistance is Rf = 0.97 x Cf x Sw x V^2, but there is uncertainty about its applicability since the fluid involved is oil, not water. The user expresses a desire for clarification on whether the formula is suitable for their problem. The conversation highlights the need for accurate formulas in hydraulic systems to determine frictional resistance effectively.
clueless
I do remember you folks to like to see where I left things. Well, let's change the arrangement. Give me formula and I will do the rest.
A hydraulics lift (type commonly used for greasing automobile) consist of a 10.111-in-diameter ram that slides in a 10.006-in-diameter cylinder. The annual space being filled with oil having a kinematic viscocity of 0.0038 ft^2/sec and specific gravity of 0.83. If the rate of travel of the ram v is 0.5fps, find the frictional resistance, F when 6ft of the ram is engaged in the cylinder...
I think this is simply evaluating expression problem once the expression is known to me. Am I underestimating the question?
Is this what you are looking for?
Rf = 0.97 x Cf x Sw x V^2 where:
Rf = Resistance in pounds
Cf = Coefficient of friction
Sw = Wetted surface
V = Velocity in ft/sec
0.97 = Constant for fresh water
Source: http://www.greenval.com/shape_part1.html
I am not sure whether I have the formula I was looking for because the fluid in my problem is oil not the water. I will check out the website you were referring to. Thanks for your time and kindness.
