How Much Water is Needed to Increase Pipeline Pressure for a Hydro Test?
To determine how much water is needed to increase pipeline pressure for a hydro test, the volume of the pipeline must first be calculated, which in this case is approximately 13.17m³. The target pressure increase to 10 barg requires understanding the difference between initial and target pressures, factoring in the pipeline's material properties and any potential expansion under pressure. Density tables for water at varying pressures can provide necessary data for accurate calculations. Additionally, using the bulk compressibility of water can help estimate the volume needed for pressure adjustments. Resources for water density tables can be found through online searches.
G Neilson
I am trying to figure if there is a calculation for working out how much water I would have to pump into a system to increase the pressure.
For example, I have a pipeline which is 2" and 6.5 km long. I worked the volume out using πr² × height so π×0.0254m²×6500m which is 13.17m³.
How do I now determine how much more water I require to increase the pressure to 10 barg?
I know the material of the pipeline matters but I am just looking for a ballpark not exact accuracy. I also know that temperature matters but for this case let's say the temperature remains constant again this is because I require a ballpark figure.
It is for a hydro test (pressure test) of the pipe. we are taking it up to 150% of its design pressure which is 414 barg so 621barg
There are tables giving the density of water at different pressures. The difference between the two pressures allows to figure out how much water has to be added at constant volume. If your pipeline expands under pressure, this could be the dominant effect, then you have to know how much it expands.
Do you know where can i Find these tables?
Google "water density table", "water density table pressure" or related things?
Another approach is to use the bulk compressibility of water, which is on the order of 5 x 10-4/MPa.
Chet
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
