Burning Bushes: The Science Behind Water Droplets and Fire Ignition
  • Thread starter Thread starter jollytime
    Optics Water
Bush fires in Africa may be ignited by water droplets acting as lenses that concentrate sunlight. The mechanism is similar to using a magnifying glass, where light is focused at a focal point to create heat. However, concerns are raised about the effectiveness of small water droplets, as their size and distortion on surfaces like grass may limit their ability to concentrate enough sunlight to ignite a fire. The discussion highlights skepticism about whether a droplet can generate sufficient heat, especially when compared to traditional lenses. Overall, the feasibility of water droplets starting fires remains contentious and requires further exploration.
jollytime
It is said that bush fires in Africa can be started by water droplets in the grass. How could this work? What actually causes the burning?
Science news on Phys.org
Have you ever used a magnifying glass in the sunlight to light fires?
yes, but i never knew how that worked..
The lens (or water drop) concentrates the light that enters it, at its focal point.
This is how some old weather-recording devices worked- a large glass ball sat in the center of a ring of paper. If the sun was out, the paper would have a char line, and if it was cloudy, there would be no line.
OK, and I'm not trying to be silly here at all, but I question the water droplet scenario.
A water droplet tends to be quite small, and I would imagine also grossly distorts while clinging to, say, a blade of grass or some such thing.
It seems to me that the droplets size itself, even if it could be shaped into an ideal lens for starting a fire, would simply be inadequate. After all, with a true lens the size of a water droplet, I tend to doubt there is enough surface area to concentrate sufficient sun-light to start a fire. Indeed, could a fire be started with a lens which has a diameter less than that of a pencil eraser?
But I could be wrong on that aspect.
Even if I were, a water droplet in nature is so grossly deformed apart from an ideal lens that the potential is even much less, it seems to me.
Just my thoughts...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
