Water falling into bucket, Force question
Water falls at a rate of 271 g/s from a height of 56.2 m into a bucket weighing 776 g. After 3.14 seconds, the total mass of water collected is approximately 0.851 kg, leading to a combined weight of 1.63 kg. The force calculation initially yields 15.9 N, but it does not account for the additional force needed to stop the water's momentum. The distance is relevant for determining the water's speed upon impact, calculated as 17.9 m/s. The discussion highlights the importance of correctly interpreting the time and speed of the falling water to solve the problem accurately.
Leeoku
13. Water falls at the rate of 271 g/s from a height of 56.2 m into a 776g bucket on a scale (without splashing). If the bucket is originally empty, what does the scale read after 3.14 s?
Answer: 2.50e+01 N
Density, estimate 1kg/m^3
F = ma (a = gravity)
1kg = 1L
In 3 seconds, .271*3 = .851 L dropped->.851 KG
Add weight of bucket, .851+.776 = 1.63 kg
F =ma
= 15.9 N
You found the weight of the water + bucket. Good! But an additional force is required to stop the momentum of the flowing water.
i actually have no clue. what I am puzzled at is why they gave us distance. the first thing that comes to mind is work, but i don't think that helps..
They gave you the distance so you can figure out the speed of the water as it hits the bucket. Hint: Use that speed to find the rate of change of the momentum of the water as it hits the bucket.
ok using v=d/t, 56.2/3.14 = 17.9 m/s
Impulse = delta p = (sum F)delta T
Delta p = 15.9*3.14
= 50 N.s
Using 50 as momentum, p = mv
50 = 17.89 M
m = 2.8 kg
Weird part is answer is given in Newtons, so mass*g = 27.4 N. Still not right, close though..
Two problems:
(1) The 3.14 s time given is not the time it takes for the water to fall from the given height.
(2) The speed of the water is not constant as it falls.
To find the speed of the water as it hits the scale, treat it as a falling body (falling from rest through a height of 56.2 m).
