Can Wavelength Be Negative if Velocity is Negative in Wave Behavior of Matter?
The discussion centers on the equation λ = h/(mv), which relates wavelength (λ) to Planck's constant (h), mass (m), and velocity (v). A key point raised is the confusion surrounding negative velocity and its implications for wavelength. It is clarified that in this context, "v" refers to speed, which is always a positive value. Consequently, the wavelength remains unchanged regardless of the direction of motion, as it is dependent on the magnitude of momentum rather than the vector nature of velocity.
daivinhtran
λ = h/(mv)
so, if the velocity is negative, how could the wavelength be negative??
Chemistry news on Phys.org
Negative velocity? We use the magnitude of the velocity -> momentum. A wavelength is not going to change if the object is moving forward or backward with the same velocity.
daivinhtran said:
λ = h/(mv)
v here stands for speed, not velocity, and is always positive.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
