Wave Equation traveling to the left
roldy
Derive the general nontrivial relation between \phi and \psi which will produce a solution to u_{tt}-u_{xx}=0 in the xt-plane satisfying
u(x,0)=\Phi(x) and u_t(x,0)=\Psi(x) for -\infty\leq x \leq \infty
and such that u consists solely of a wave traveling to the left along the x-axis.
d'Alemberts Formula
So for a wave traveling to the left, the equation takes the form of
u(x,t)=G(x+ct)
Is this correct? It was my assumption that wave equations have two parts to them, i.e F(x-ct) and G(x+ct).
I think I know the general procedure of doing this, although I am probably wrong as I am just guessing here. We were never shown in class how to derive relations between the functions of the initial conditions.
I think that I would probably work in reverse from u(x,t)=G(x+ct)
So with the initial conditions...
<br /> u(x,0)=\phi(x)=G(ct)<br />
<br /> u_t(x,0)=\psi(x)=cG&#039;(ct)<br />
After this I got stuck.
Assume that the general solution is:
<br /> u(t,x)=f(x-t)+g(x+t)<br />
and use the two initial condition.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
