Wave function at high symmetry point
The discussion focuses on the conditions under which the wave function at the \Gamma point can be a real function. It is established that, in the absence of spin-orbit coupling, the wave functions can be chosen to be real due to time-reversal symmetry, represented by complex conjugation. However, when spin-orbit coupling is considered, this guarantee is lost, leading to Kramers degeneracy where wave functions cannot be simply represented as real. The conversation also touches on the implications of using Bloch waves and the effects of boundary conditions on the choice of periodic functions.
  • Understanding of wave functions in quantum mechanics
  • Familiarity with Bloch's theorem and Bloch waves
  • Knowledge of time-reversal symmetry in quantum systems
  • Concept of spin-orbit coupling and Kramers degeneracy
  • Study the implications of spin-orbit coupling on wave functions in quantum mechanics
  • Learn about Kramers degeneracy and its effects on electronic states
  • Explore the role of boundary conditions in quantum systems, specifically Born-von Karman conditions
  • Investigate the mathematical formulation of time-reversal symmetry in periodic potentials
Physicists, quantum mechanics students, and researchers interested in solid-state physics and the behavior of wave functions in high symmetry points of the Brillouin zone.
jianglai
How to prove that wave function at \Gamma point can always be a real function? I know it is not true for general k point, but for \Gamma and other high symmetry point like X, is there a simple proof?
Thanks!
This is hard to prove as it is wrong in general. E.g. once spin orbit coupling cannot be neglected, the orbitals have to be chosen complex.
Hmm. If we ignore spin-orbit then this seems easy. Note that the complex conjugate of the Bloch wave at gamma is also a solution of the Schrödinger equation. That means the real and imaginary parts are separately solutions. A similar argument should work at other high-symmetry points if -k = k + K where K is a reciprocal lattice vector.
A clean discussion involves the assumption and discussion of time reversal symmetry. If there are no spin orbit coupling effects, time reversal will be represented by complex conjugation and the single particle wavefunctions in a periodic potential can always be chosen real as then E(k)=E(-k) so that instead of the solutions \psi_k(x)=u_k(x)\exp(ikx) and \psi_{-k}=(\psi_k(x))^* real valued combinations can be chosen. For k=0, only one real function will be obtained.
If spin orbit coupling is taken into account, time reversal is no longer just complex conjugation so that it does not always guarantee real valuedness. This is known as Kramers degeneracy.
That's right, but I think we want to keep our wave-functions as Bloch waves. In other words, we're really aking where in k-space we can choose the periodic function u_k(r) to be real. I guess you could do what you said for all k if you wanted to work with stationary boundary conditions (in opposition to the conventional Born-von Karmen).
I think it also works with Born- von Karman boundary conditions. So basically the only reason why we have to use complex u_k is because we insist on complex exp(ikx) instead of sin(ikx) or cos(ikx).
Thank you both for the reply! I think I get a sense of it now. Without spin-orbital coupling, for any k, \psi_{nk}(r) and \psi_{nk}(r)^* = \psi_{-nk}(r) are degenerate (in H). But Bloch state are simultaneous eigenstates for both H and translation T_R, and only at -k = k + G are \psi_{nk}(r) and \psi_{-nk}(r) degenerate in T_R as well, which means we can take a linear combination of them and get rid of the imaginary part. For a general k however, \psi_{nk}(r)+\psi_{-nk}(r) would be a real-valued eiginstate of H that's not a Bloch state.
Couldn't have formulated it better!
  • · Replies 20 ·
