Wave functions and dynamic question
The wave function provided describes a wave on a string, and the discussion focuses on determining key wave properties such as wavelength, frequency, and the number of waves and cycles. The correct wave number (k) is identified as 44.4 m^-1, which leads to the calculation of wavelength (λ) as 0.141 m, not 278.97 m as initially thought. The frequency (f) is calculated using the angular frequency (w), resulting in approximately 115.4 Hz. The number of waves in 1 meter and the number of complete cycles in 1 second can be derived from the wavelength and frequency, respectively. Clarifications on units and relationships between k, λ, and f are emphasized throughout the discussion.
yjk91
The displacement from equilibrium caused by a wave on a string is given by
y(x, t) = (−0.00217 m)sin[(44.4 m−1)x − (728 s−1)t].
i need to find
(b) number of waves in 1 m
waves
(c) number of complete cycles in 1 s
cycles
(d) wavelength
(e) frequency
i first thought the wavelenght was 44.4m because of the formula
Acos2pi(x/λ - t/T)
but then i realized that you had to use the other formula : Acos(kx - wt)
so k = 1/44.4m = 2pi / λ
so λ wave length is 278.97m ?? is this right?
then w = 2pif = 1/728s
so f = 2.186 * 10 ^-4 HZ
and with λ and f you can find the Velocity
not sure if i found λ and f right? can you please tell me if i did it right?
i'm guessing you find this by 1/λ
and you find this by doing 1/ T
i just want to make sure this is right. if the λ and f are right so i can get the rest of the answer
thank you!
The units look weird. Instead of m-1 use m-1 or 1/m. The same for s-1.
So the wave is y(x,t)=(−0.00217 m) sin[(44.4 m−1)x − (728 s−1)t].
No, k=44.4 m-1. Otherwise your way of solving the problem will be correct.
ehild
ehild
so k =44.4m^-1
does that equal to k = 1/44.4m what does m^-1 mean?
yjk91 said:
so k =44.4m^-1
No, because k=1/44.4m is the same as 1/44.4 m^-1, which is 0.0225 m^-1. k is proportional to the inverse of the wavelength and wavelength is measured in m, so you'd expect the units to be m^-1.
9K
