Wavelength, frequency, and E field amplitude from magnetic field equation
The discussion focuses on calculating the wavelength, frequency, and electric field amplitude of a magnetic wave given its magnetic field equation. The wavelength is determined using the formula λ = 2π/k, yielding a value of approximately 6.28 x 10^-7 m. Frequency can be derived from the wave's speed and wavelength using the relationship c = λf. The amplitude of the electric field is found using the equation E = cB, where c is the speed of light and B is the amplitude of the magnetic field. The conversation highlights the interconnections between these parameters in electromagnetic wave equations.
Linus Pauling
1. The magnetic field of an electromagnetic wave in a vacuum is B_z= ( 3.0 uT )*sin(( 1.00*107)x - omega*t) , where x is in m and t is in s.
What is the wavelength and frequency of this magnetic wave? What is the amplitude of the E field?
2. wavelength = 2pi/k
frequency = f = 1/T = omega/2pi
E = cB
3. k = 1*107, so lambda = 2pi/k = 6.28*10-7
How do I find frequency without knowing omega?
How do I go about obtaining an actual value for E0? It doesn't seem like E =cB will be enough here...
How are the frequency and the wavelength related?
ehild
Yeah I got frequency since I posted this from c = lamba*f but I'm stuck on E still
You need the amplitude of the E field and it is c times the amplitude of B. What is the amplitude of B?
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
