Wavelength Function and Diffraction Orders Explained
The discussion centers on the symbol "m" in the equation dsinθ = mλ, where "m" represents the order of diffraction in a fluorospectrometer context. The user seeks clarification on the significance of 1st and 2nd order diffraction, particularly in relation to observed scattering and the wavelength function. It is established that higher order diffraction peaks, while present, are typically less intense and may not be visible depending on the spectrometer setup. Additionally, the constant shifts in absorption spectra peaks can be explained using this diffraction equation.
  • Understanding of diffraction orders in optics
  • Familiarity with the equation dsinθ = mλ
  • Knowledge of fluorospectrometry and its operational principles
  • Basic concepts of absorption spectra and peak shifts
  • Research the principles of diffraction and how they apply to spectrometry
  • Learn about the operation of fluorospectrometers and their configurations
  • Explore the relationship between diffraction orders and intensity in spectroscopic analysis
  • Investigate the mathematical modeling of peak shifts in absorption spectra
Researchers, optical engineers, and spectroscopists seeking to deepen their understanding of diffraction phenomena and their implications in spectroscopic measurements.
anakat-
an someone explain to me the symbol "m" in dsin[tex]\theta[/tex]=m[tex]\lambda[/tex],
where m is the order of diffraction (or whatever it's called). I am using a fluorospectrometer at which the sin[tex]\theta[/tex] is always equal to 1. This instrument can fix the excitation [tex]\lambda[/tex]. The main point is that scattering of the 1st and second order is observed.
Can somebody PLS explain to me what it means to be in the "1st and/or 2nd order". ie How does this pertain to the actual wavelength function.. I understand that it can be the 1st and 2nd minima after the 1st maxima but am having troubles seeing the big picture.
Another point to consider is that in any absorption spectra, the shifts (delta cm-1) in the peak are constant and I know this can be explained by the equation above. What I am looking for, is an explanation as to why the shifts are constant?
Thank you :-p
Science news on Phys.org
The best way that I can think of to explain this is by example. A spectrometer spatially resolves the spectrum of the light source that you are analysing with it. If you take a source that has a narrow bandwidth like a c.w. laser then the spectrum of the laser will only have a single line, corresponding to the wavelength of the laser. If you then put this source into the spectrometer you may see not one line but several corresponding to the different diffraction orders. Generally the higher order diffraction peaks are much less intense so depending upon your setup you may not see them at all.
  • · Replies 0 ·
