The statement as I heard/read it was 'the wavelength has to be much larger than the object being imaged'. Note: this is object size as a whole entity and not the separation between resolvable features. This reason was given as one of the requirements for MR imaging and one of the reasons imaging at really high magnet strengths would be tricky. The wavelength used for 1H MR imaging at 1.5T(most common magnet strength used) is 4.5m, which is much larger than about 0.25m bore of the magnet used to image humans. MR imaging under these conditions is considered to be reasonably compliant due to this aforementioned statement. The wavelength at 9.4T, (currently considered a really high magnetic strength), is just under 1m, and was stated that imaging at 9.4T would be challenging due to the wavelength to size of object condition. Some, but not all, of the problems that were mentioned were: hot spots, nulls, standing waves. The resolution seems to be better at 9.4T than at 1.5T so I do not think this has to do with the standard wavelength to molecule separation restriction of achievable resolution.
Everywhere I have read this just states it without explanation of what the cause or effects related to this requirement would be. When I ask lecturers that have made this statement they appear to side step around giving any actual answer. Since I have come across this statement many times I would like to understand what is meant by it. I do not have any clue as to how the size of the object would manifest itself as a problem in relation to the wavelength. I assume that the probability of photon / proton(neutron) interaction is dependent on the wavelength somehow and this produces spatial variations in this probability, but this is only a guess.
Thanks,
Fred
