What Are the Approximate Wavelengths of Different Colors?
  • Thread starter Thread starter prasanaharani
    Wavelengths
The discussion focuses on the approximate wavelengths of various colors, specifically blue, green, bluish-green, yellow, orange, violet, and red, expressed in both angstroms and meters. Participants emphasize that this information is readily available in physics textbooks or through online searches. There is a reminder that homework questions should be posted in the appropriate forum and that users need to demonstrate their own efforts to receive assistance. The thread was subsequently moved to the Homework Help section for better organization. Proper etiquette in forum participation is highlighted throughout the conversation.
prasanaharani
i want to know the approx wavelengths of the following colours
blue
green
bluishgreen
yellow
orange
violet
red
the wavelengths should be in amstrong unit and also in meter .
This info can be found in any decent physics textbook or by a simple google search. It sounds like you're asking a homework question here, and with no effort, you shall receive no help.
[I've requested that this be moved to the homework section, so don't go double posting again.]
Thread moved to Homework Help, Intro Physics.
prasanaharani, Welcome to the PF. Please be sure to post homework and coursework questions in the Homework Help forums, and you must show us your own work in order for us to help you.
