shmurr
- 8
- 0
Is the velocity of water waves created in a container affected by the temperature of water. How?
The discussion centers around the influence of temperature on the velocity of water waves in a container. Participants explore the relationship between temperature, wave speed, and various physical properties of water, including density and surface tension, while contrasting water waves with sound waves.
Participants express differing views on the impact of temperature on water wave speed, with no consensus reached. Some maintain that temperature has no effect, while others suggest it may have a minor influence under certain conditions.
Discussions include references to specific theories and documents that outline the conditions under which wave speed is calculated, emphasizing that assumptions about temperature's influence may depend on the type of wave and the specific context of the discussion.
This discussion may be of interest to those studying fluid dynamics, wave mechanics, or anyone curious about the physical properties of water and their effects on wave behavior.
Actually if you look at the phase velocity, [itex]c[/itex], for shallow water waves:Bobbywhy said:Surface waves on a fluid such as water do not obey the same laws that govern sound waves in water, so it’s not correct to assume they are affected by the same variables, in this case, temperature.
In this Wiki entry there is no mention of temperature affecting the phase velocity (also called “celerity” or “phase speed”):
http://en.wikipedia.org/wiki/Dispersion_(water_waves )
snorkack said:...is the speed of water waves also heavily influenced by the changes in the surface tension of water?
The linear dispersion relation is usually understood for its behavior in two limits: In the limit of long waves (shallow water waves), the phase speed is affected only by depth, so that all waves propagate at the same speed. For the opposite limit (deep water waves), the wavelength matters but not the depth, and the waves become dispersive.Bobbywhy said:According to linear theory for waves forced by gravity, the phase velocity depends on the wavelength and the water depth. For a fixed water depth, long waves (with large wavelength) propagate faster than shorter waves.
In the case that depth matters (shallow water waves), then one might suppose that the temperature affects the phase speed through the (surely microscopic) change in depth, as suggested in posts three and eight.The phase velocity of an approximately sinusoidal wave is proportional to the square root of the wavelength. These are the waves described in the five examples given in post number five on March tenth that showed no effect of temperature change on phase velocity.
