How Does Air Temperature and Pressure Affect Density Calculations?
  • Thread starter Thread starter Claire_01
    Weather
The discussion focuses on calculating the temperature of dry air at an airport based on a measured station pressure of 1014 mb and a known density of 1.3 kg/m^3. The Ideal Gas Law is applied, with the formula P = ρRT, where R is the gas constant for dry air. After determining the initial temperature, the conversation shifts to recalculating the air density when the surface pressure decreases to 1010 mb while keeping the temperature constant. Participants emphasize the importance of unit consistency in these calculations. The thread highlights the application of thermodynamic principles to understand how air temperature and pressure affect density.
Claire_01
A weather station at the airport measured a station pressure of 1014 mb. The density of dry air is 1.3 kg/m^3. The gas constant for dry air, R, is 287 J/kg-K. Calculate the temperature of the dry air at the airport.
1 mb = 100 J/m ^3
AND
The surface pressure at the airport then decreased to 1010 mb but the air temperature reamined the same (as the answer in #1). Calculate new density of air.*I'm really confused and I would greatly appreciate it if someone can walk me through this problemThis is what I have so far, I know you have to use the Ideal Gas law
P= p R T
1014 mb = 1.3 kg/m^3 x 287 j/kg-k x T
Hey, that looks really good so far! Surely you know enough algebra to take it from there. Just as a comment though, make sure you watch your units!
