Weight in an Elevator and Normal Force
A person weighing 200 lbs in an elevator experiences different scale readings based on the elevator's motion. When the elevator moves down at a constant speed, the scale reads 200 lbs, as there is no acceleration. However, when the elevator begins to decelerate at 4.9 m/s², the scale reading changes due to the upward acceleration opposing the downward motion. The correct interpretation of the forces reveals that the scale would read less than 200 lbs while decelerating. Understanding the direction of acceleration is crucial for solving such problems accurately.
PeachBanana
A person who normally weighs 200 lbs is standing on a scale inside of an elevator. The elevator is moving downwards at a constant speed of 7.0 m/s and then begins to slow down at a rate of 4.9 m/s^2. Before the elevator begins to decelerate, the reading of the scale is ____, and while the elevator is slowing down, the scale reads:
A. 200 lbs, 100 lbs.
B. less than 200 lbs, 300 lbs
C. less than 200 lbs, 100 lbs,
D. 200 lbs, 300 lbs.
E. 200 lbs, 200 lbs
F = ma
All a scale knows is the normal force being exerted on it.
Initially there's no acceleration so weight is the same. That eliminates B and C. It then begins to decelerate at 4.9 m/s^2. I thought either which way acceleration is negative. Your velocity is going from being positive to less positive.
F - mg = ma
F = mg + ma
F = 200 lbs (9.8 m/s^2 - 4.9 m/s^2)
I know the units aren't right and my teacher said I wouldn't have to convert but I don't know why I would ADD 4.9 m/s^2. I thought the problem was just giving the magnitude of the deceleration.
if it's slowing down, in which direction does that imply the acceleration is pointed?
also in questions like this it is possible to use your experience to answer it, that is, if you've got enough experience with elevators.
Ok. I see. If velocity is moving down, in order for it to be slowing down, acceleration has to point in the opposite direction, up.
yep ;)
always make sure you pay close attention to the wording of a problem in order to determine the directions in which the vectors are pointed
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
