Calculating Minimum Horsepower Needed for Object Movement
To calculate the minimum horsepower needed for moving an object, the correct approach involves understanding that work equals force multiplied by displacement. The formula weight times distance does not directly equate to power, as power is work done over time. Factors such as friction, rolling resistance, and air resistance can significantly affect the force required, meaning the relationship isn't straightforward. The initial calculations may yield high horsepower values due to these overlooked variables. Accurate assessments must consider all forces acting on the object to determine the true minimum horsepower required.
rm121181
If weight x distance over time equals work done. Work done divided by time will give me work done over time foot pounds. Foot pounds can be converted to horsepower. So I should be able to find minimum horse power needed to push
a known weight a known distance in a known time right? Am I missing something? It seems like my horsepower needed numbers are very high.
set up the problem
horse-power
; is an unit of power equal to 550 foot-pounds per second (about 750 watts).
No, weight x distance = work done; dividing that by time gives power.
No idea what that means. The work done over the time a runner's foot pounds the pavement?
No, foot pounds is a measure of work, not power.
Only if the distance is vertical. The correct equation is..
Work = force * displacement
No because the force required to move an object is not equal to the weight. For example the force might depend on friction, rolling resistance, air resistance etc some of those might be effected by weight but it might not be a simple relationship.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
