Boogeyman
- 75
The astronaut in space feels weightless, yet he has weight. Could you guys explain? I have an idea but not quite sure...
According to Newton's first law, the answer is no.Boogeyman said:Does a spacecraft in orbit around the Earth need a force (i.e from the rockets) to maintain constant speed? Why?
I think the answer is yes but I can't give a good reason..my mind keeps telling me the spacecraft will keep constant velocity but the acc. due to gravity (3N/kg) obviously can't be ignored...
cevdet.erturk said:I think u r confused about the meanings of weight and mass.
weight=gravity.mass and it depends where u stand. Earth, mars, moon or smthn.
But mass is same everywhere. As it is in space.
Note: Astronaut has an accelaration? But feeling of jumping window (till touchin ground) contains an accelaration. I mean these should be different feelings from each other.
russ_watters said:According to Newton's first law, the answer is no.
The acceleration due to gravity is perpendicular to the direction of motion, so it does not affect the speed, just the direction. That's what an orbit is.
No. If the spacecraft is in a stable orbit around the earth, it needs no rockets to maintain its speed.Boogeyman said:Does a spacecraft in orbit around the Earth need a force (i.e from the rockets) to maintain constant speed? Why?
No. Gravity exerts a net force on the object and the object is accelerating as it moves in its orbit.mathman said:The net force on an object (satellite, astronaut, moon) in orbit around the Earth is zero.
Centrifugal force is a "fictitious" force that is an artifact of viewing things from a rotating reference frame. (No need to use a noninertial frame here.)The Earth's gravity is balanced by the centrifugal force resulting from being in orbit.
If there were no force acting on the object, it would keep going in a straight line at constant speed. But gravity pulls it in a curved orbit. If the object doesn't have enough speed, it will crash into the earth.If the object was not in orbit, it would fall to earth. If the Earth's gravity stopped, it would go on a straight line tangent to the orbit (at the point it was when the Earth disappeared).
Use Newton's 2nd law. Hint: Consider the centripetal acceleration of the spacecraft (assuming it's a simple circular orbit).Boogeyman said:How do I calculate speed of the spacecraft when all I'm given is mass(1000kg), radius(12000km) and gravitational field strength(3N/kg)? I know weight is 3000N, but I can't make the connection..
Shooting star said:The spacecraft does not need any force from the rockets to keep it orbiting the earth, provided the orbit does not pass through the atmosphere. In circular orbit the speed remains constant, in elliptical orbits the speed will vary. But the craft is revolving around the Earth due to gravity only,which you had rightly pointed out, cannot be ignored
Does the moon need rockets to be in orbit around the earth? Or the Earth about the Sun ? Now you understand, I hope.
r=12000kmDoc Al said:Use Newton's 2nd law. Hint: Consider the centripetal acceleration of the spacecraft (assuming it's a simple circular orbit).
If the orbit is not circular, than work is being done, and there are changes in speed. The total energy, which is the sum of gravitational potential energy and kinetic energy will be a constant.Shooting star said:How does it follow from Newton's 1st law?
If the orbit is not a circular one, then the force due to gravity is not perpenicular to the direction of motion, except at the perigee and the apogee.
Almost. The radius is given in km, not meters. Convert! (But you have the right idea.)Boogeyman said:r=12000km
mass of spacecraft =1000kg
grav. field strength= 3N/kg
So the acceleration can be shown to be equal to v²/r where v is the speed around the orbit and r is the orbit radius..and F=ma. So using Newton's second law, a=3000N/1000kg=3m/s²
If a=3m/s², then 3m/s²=v²/12000 => 3x12000=v² so v=190m/s
I think that's it guys?
Jeff Reid said:If the orbit is not circular, than work is being done, and there are changes in speed.
The post I responded to asked about a constant speed scenario, which must be a circular orbit.Shooting star said:You are merely repeating what I had said. That's not what I had asked. I was curious when the mention of Newton's first law was made in a post. See my original posting.
Let's just forget it. It's not important.
D H said:The answer is no. The Moon doesn't need thrusters to stay in orbit around the Earth. Why should a satellite?
