What are the advantages and disadvantages of n-pole motors?
  • Thread starter Thread starter yrjosmiel
    Motor Motors
N-pole motors, including brushed DC motors, exhibit a relationship where more poles can lead to higher torque but lower RPM, although this is not as straightforward as in AC motors. The synchronous speed of AC machines is directly influenced by the number of poles, but for DC motors, speed is primarily determined by applied voltage and field strength, not pole count. Increasing the number of poles reduces the number of armature slots per pole, complicating the design and performance dynamics. Understanding the trade-offs between different winding types, such as Lap and Wave, is crucial for motor design. Overall, while pole count affects torque, it does not dictate speed in the same manner as in AC motors.
yrjosmiel
From what I've understand now, it is like in a brushed DC motor, the more poles you have, the less RPM but higher torque. Can anyone confirm?
Have you tried an internet search ?
Yes, I have. No helpful results so far.
A great many AC and DC machines can be called "n-pole motors", where "n" is an even number of poles (2,4,6,8,etc).
For an AC machine, synchronous speed (in RPM) is f*(2/p)*60, where f=AC line frequency, and p= the number of poles.
i.e. for a 2 pole motor operated at 60 Hz line frequency, 60 Hz * (2/2) * 60 = 3600 RPM.
Do a search on "motor poles" and read up.
Did a search and all I got were about induction motors when I'm looking for the ones about brushed DC motors.
Anyway. For brushed DC motors (given the same current), does more poles mean more torque and less RPM?
Here's a pretty good introduction to DC motors
https://www.saylor.org/site/wp-content/uploads/2012/07/8a-DC-motors-rev-3-091115-CCupload.pdf
While it's true that more poles gives more electrical degrees per mechanical degree of rotation
it would be misleading to say that number of poles for a DC machine determines speed like it does in an AC machine.
Should you accept it as a premise you'll wind up making mistakes in your thinking.
Armature tangential velocity in a DC machine is ratio of applied voltage and field strength , neither of which depends on number of poles.
Speed and torque will be more affected by motor's diameter and length than by how many poles it has.
More poles means less armature slots per pole , so everything is inter-related
but going down the line of thought you propose will cause confusion.
Look up Lap vs Wave wound armature and you'll get into the tradeoffs designers use.
Likes yrjosmiel, Asymptotic and cnh1995
Thank you for the good read, mate!
