What are the masses of two objects given their velocities and total momentum?
  • Thread starter Thread starter MarineBio
    Momentum
The problem involves two objects with unknown masses, m1 and m2, moving with known velocities on the x and y axes, respectively. The total momentum of the system is given, along with its direction. Participants are tasked with finding the masses based on this information.
  • Some participants express uncertainty about how to begin solving for the masses without additional information. Questions arise regarding the need for direction or unit vectors for the velocities provided. Others discuss the implications of momentum being a vector quantity and suggest resolving momentum into components.
Participants are exploring different interpretations of the problem and discussing the setup. Some guidance has been offered regarding the resolution of momentum components, but there is no explicit consensus on the approach to take.
There is mention of potential missing information, such as diagrams or additional details about the direction of velocities. The discussion reflects a concern about the clarity of the problem statement.
MarineBio
Object 1 has a mass m1 and a velocity 1 = (2.70 m/s) on the x-axis. Object 2 has a mass m2 and a velocity 2 = (2.95 m/s) on the y-axis. The total momentum of these two objects has a magnitude of 18.6 kg·m/s and points in a direction 66.5° above the positive x-axis. Find m1 and m2.
I honestly don't even know where to begin. I am finding it impossible to determine mass 1 and mass 2 without knowing one or the other. How do I even set this one up?
Hi MarineBio,
MarineBio said:
Object 1 has a mass m1 and a velocity 1 = (2.70 m/s). Object 2 has a mass m2 and a velocity 2 = (2.95 m/s). The total momentum of these two objects has a magnitude of 18.6 kg·m/s and points in a direction 66.5° above the positive x-axis. Find m1 and m2.
Was there some more information given, perhaps in a diagram? (For example, showing that mass 1 goes along the x-axis and mass 2 goes along the y-axis, or something like that.)
I'm surprised that they would say the velocity is 2.7m/s (for example) without giving a direction or a unit vector. If they did not give a direction, it seems like they would have referred to it as just the speed.
alphysicist said:
Hi MarineBio,
Shoot, when I copy/pasted it did not include the x and y hats.
V1 is on the x axis
V2 is on the y axis
That makes things relatively simple! Since momentum is a vector quantity the component in the x and y directions should be: 18.6cos(θ) and 18.6sin(θ) respectively. Just resolve the components!
Since V1 is on the x-axis: m1V1 = 18.6cos(θ)
A similar argument can be made for the y-axis component.
V1 is on the x axis
V2 is on the y axis
Okay, then you can add up the momentum: the momentum of m1 + momentum of m2 = total momentum.
Remember though that since momentum is a vector quantity, and this is a 2-D problem, you'll end up needing to have a momentum equation for the x-direction, and a momentum equation for the y-direction.
Does that help? If not, please post what you are trying.
Ha! I was making that one WAY more difficult than it actually was. Thank you, problem solved!
(this is such a great forum) :smile:
  • · Replies 20 ·
  • · Replies 30 ·
