What are the sub sequances here
  • Thread starter Thread starter transgalactic
transgalactic
1/2 , 1/3 , 2/3 , 1/4 , 2/4 , 3/4 , 1/5 ,2/5 ,3/5 ,4/5 ...
i can't see the patterns here?
There are infinitely many subsequences of any sequence: just delete some elements.
For the pattern, first look at the denominators only, and then look at how the numerators change for each denominator.
ok i see numbers
1/2 2/3 3/4
a1 a3 a6
but they don't have constant gap between then
so i can't do a formula for that
I see two things going on here... the denominator increases, and with each new denominator d a sum of 1/d to (d-1)/d fractions. If you are familiar with programming this sequence would easily be described with a nested loop.
That should get you started ;)
i see that too but i need to break into sUb sequences
what you say doesn't help me with that
As previously stated there are infinite subsequences in this sequence... is the original question more specific?
ok i need at least two
and their location n(k) formula
transgalactic said:
ok i see numbers
1/2 2/3 3/4
a1 a3 a6
To describe the sequence 1, 3, 6, 10, 15, ...,
n(1) = 1
n(2) = n(1) + 2
n(3) = n(2) + 3
n(k) = ?
If you are familiar with Pascal's triangle, you can get a "nicer" expression from it.
this is a recursion
i need linear n(k) formula
edit:
Take the numbers with numerator 1. They clearly form the sub-sequence 1/(k+1) k=1...∞
Now, these occur at:
1/2 -> position 1
1/3 -> position 2
1/4 -> position 4
1/5 -> position 7
1/6 -> position 11
1/n -> position ??
Hint: the distance between positions increases by one every time
Double hint: ½n² + ½n + 1
One thing I see is 1/2, 2/3, 3/4, 4/5, ... which clearly converges
Another is 1/3, 1/4, 1/5, ... which also converges.
As has been pointed out there are an infinite number of subsequences in any sequence. Perhaps a better question would be, "What are the subsequential limits?"
i need to find the sub sequences in order to find their limits
so there may be endless number of limits
unless this series converges
in which case all of the sub sequences limits equal
the limit of the sequence
what to do in this case:
