What are the two possibilities for its x component problem?
  • Thread starter Thread starter mathcrzy
    Component
The discussion focuses on determining the x component of a vector in the xy plane with a magnitude of 85.0 units and a y component of -40.0 units. The two possible values for the x component are 75 and -75, derived using the Pythagorean theorem. Additionally, if the x component is known to be positive, the resultant vector that, when added to the original vector, results in a vector of 85.0 units pointing entirely in the -x direction has a magnitude of -85 units.
  • Understanding of vector components in the xy plane
  • Familiarity with the Pythagorean theorem
  • Knowledge of vector algebra
  • Ability to work with magnitudes and directions of vectors
  • Study vector addition and subtraction techniques
  • Learn about vector representation in component form
  • Explore the implications of negative vector components
  • Investigate the use of the Pythagorean theorem in physics problems
Students and professionals in physics, engineering, and mathematics who are working with vector analysis and require a deeper understanding of vector components and their applications.
mathcrzy
You are given a vector in the xy plane that has a magnitude of 85.0 units and a y component of -40.0 units.
(a) What are the two possibilities for its x component?
____
____
(b) Assuming the x component is known to be positive, specify the vector which, if you add it to the original one would give a resultant vector that is 85.0 units long and points entirely in the -x direction.
Magnitude
____
Direction
____°
A. Start by using your Magnitude Formula (pythagorean theorem) and look x value (you will get 2 as its a square root).
93.9 and -93.9?
mathcrzy said:
93.9 and -93.9?
careful. (x-component)^2 + (y-component)^2 = magnitude^2.
thanks. i got it 75 and -75. now what is the second part of the question asking? would it be -85?
No. Just use vector algebra. What is the original vector? what is the resultant vector? write them in the form x\vec{i} + y\vec{j}.
  • · Replies 21 ·
  • · Replies 16 ·
