What Coefficient of Friction Is Required for a Car on a Banked Curve?
  • Thread starter Thread starter hofluff87
    Friction
To determine the coefficient of friction required for a car negotiating a banked curve, the car's speed must be converted from km/h to m/s. The maximum speed for the curve is 60 km/h, equivalent to 16.67 m/s. The angle of the bank must be considered, as it affects the forces acting on the car. The equations of motion must account for both the centripetal force and the gravitational force components. Ultimately, the calculations indicate that the coefficient of friction needed is approximately 0.202, but further adjustments may be necessary to ensure accuracy.
hofluff87
A car moving at 41 km/h negotiates a 140 m-radius banked turn designed for 60 km/h. What coefficient of friction is needed to keep the car on the road?
Ok can some one tell me what i did wrong?
Fc= (m*V2)/r = m µ g
Vmax= square root of ((µ) g r)
60 = square root (µ*9.8*140)
for mu i got 2.62391
i used the 60 km/h because that was the maximum velocity of the curve
how ever when i checked it its wrong ... my book does not say anything about the friction involved with a banked curve. help:cry:
hofluff87 said:
A car moving at 41 km/h negotiates a 140 m-radius banked turn designed for 60 km/h. What coefficient of friction is needed to keep the car on the road? Ok can some one tell me what i did wrong?
Isn't there an angle of bank for the curve?
Edit: I see it's designed for 60 km/h.
As for your speed you will need to convert them to m/s from km/h.
This equation is not right because you haven't accounted for the angle of the bank.
i changed the speed from km/h to m/s 60 km/h = 16.67 m/s
there is no given curve however:
if Fc cos (theta) = Weight sin (theta)
(V2/r) cos (theta) = g sin (theta)
then (V2/ g r ) = sin theta / cos theta = tan theta
theta = tan inverse (V2/ g r)
theta = 11.446
but how does that help me find mu?
btw after adjusting the km/h to meters/ s for mu after plugging it in the equation i got .202 but it was also wrong
theta = 11.446
Consider first the 60km/h case.
Draw a force diagram. There is the centripetal force. There is the gravitational force down the incline. Since they say it is designed for 60km/h I think they must mean that there is no slipping for any μ.
Mass drops out. Leaving θ, because you know g and V and R
Now develop your equation for the slower speed. There your MV2/R plus your μ*g component must be sufficient to balance the downward force of the m*g*Sinθ component.
