What Determines the Velocity and Mass of the Second Ball in a Collision?
  • Thread starter Thread starter RIO0311
The discussion focuses on a physics problem involving a collision between two balls, where one ball has a known mass and velocity, while the second ball is stationary before the collision. After the collision, the first ball reverses direction, prompting questions about the velocity and mass of the second ball. Participants suggest applying the conservation of momentum to solve for the unknowns. The conversation emphasizes the importance of understanding the principles of momentum conservation in collision scenarios. Ultimately, the solution hinges on correctly applying these principles to determine the second ball's properties.
RIO0311
A 0.220 kg ball traveling east at 8.5 m/s collide with a stationary ball. After the collision the first ball bounce back west at 3.7 m/s. What is the velocity and mass of the second ball?
Which conservation law do you think might e applicable?
