What Does Enthalpy of Vaporization Mean Beyond the Boiling Point?
  • Thread starter Thread starter Silvius
    Vaporization
The discussion centers on the concept of enthalpies of vaporization (ΔH_{vap}) and their temperature dependence. Initially, there is confusion about whether ΔH_{vap} is only relevant at a substance's boiling point. It is clarified that while ΔH_{vap} is often discussed at boiling point, it can also apply at lower temperatures, where the probability of molecules escaping into a gaseous state exists. The conversation highlights that at room temperature, water does vaporize, albeit at a lower probability than at boiling point, where the average kinetic energy of molecules is higher. The distinction is made between viewing ΔH_{vap} as the energy needed to add to the system versus the energy required for molecules to escape. This understanding helps reconcile the concept of latent heat at boiling point with the energy dynamics at lower temperatures. The analogy of an open pot of water illustrates how vaporization occurs with and without temperature change, reinforcing the idea that the processes are fundamentally similar regardless of the temperature context.
Silvius
Hey guys,
I was just hoping to clear something up regarding enthalpies of vaporization.
The idea of the heat of vaporization for a substance being "temperature dependent" is confusing me, as I had been under the impression that these quantities were only considered at the boiling point of a substance. That is, you impart a certain amount of energy to raise the temperature of liquid water at some pressure to 100°C, and then the ΔH_{vap} represents the extra energy which needed to be imparted to then convert that liquid water to water vapour (without any raise in temperature).
What, then, would a ΔH_{vap} at some other temperature represent, given that you are not at a sufficiently high temperature for vaporization to occur...?
Thanks!
Chemistry news on Phys.org
So you are suggesting that water at room temperature doesn't vaporise and will stay in the glass forever?
Hmm, no, but I've always understood that phenomenon in a probabilistic context. That is, at any given time there is some probability that any given molecule of water possesses sufficient energy to escape into a gaseous state.
Is it this "sufficient energy", then, which is represented by the heat of vaporization at this lower temperature...?
Is this different at boiling point?
No, but the probability is much higher, because the average kinetic energy of the water molecules is higher? Hmm.
I feel like you are starting to see it is exactly the same process, don't you?
I think so... And thus, that enthalpies of vaporization tend to decline with temperature represents the greater probability of molecule-escape?
I suppose the intuition clash came from considering ΔH_{vap} as "the energy which needs to be added to the system" as opposed "the energy required for molecule escape". The former notion lends confusion to a system below the boiling point - any energy in such a scenario provided, say, by something like a flame would raise the temperature, rather than being latent heat, whereas at the boiling point it would be latent heat... I think. Hopefully that makes sense! Haha.
Imagine an open pot of water. Water vaporises and temperature goes down, so the heat is not latent - that is, we observe temperature change. Now imagine the same pot but the content is thermostatted now, so that the temperature is constant. Water vaporises and takes heat away, but the temperature is constant, so the heat is - in a way - a latent one. Now imagine water is boiling. Temperature is kept constant because boiling occurs at a well defined temperature, but apart from the reason why the temperature is constant, is there any substantial difference between both scenarios? Temperature is constant, you add heat, water vaporises taking this heat away. Same thing.
Ahh yes, this makes sense. Thank you!
