What does it mean first 2 flips are heads
  • Thread starter Thread starter zeion
    Mean
The discussion revolves around interpreting the phrase "first 2 flips are heads" in the context of a coin-tossing problem. It clarifies that this phrase does not restrict the outcomes of the remaining flips, meaning sequences like {HHTHH} or {HHTTT} are valid as long as the first two flips are heads. The probability of getting heads on the first two flips is calculated as 1/4, derived from multiplying the probabilities of each individual flip. Additionally, when considering a die roll, the combined probability of the first two flips being heads and rolling a 2 is determined to be 1/24. The conversation emphasizes the importance of clearly defining events in probability scenarios.
zeion
what does it mean "first 2 flips are heads"
I have a problem that asks me the find the probability that the first 2 flips after tossing 6 coin is heads.
does it mean that it is the result {HHTTTT}?
or does it include results like {HHTHH}, {HHTTH}, etc?
I'm not 100% clear on what your question is. If the question is asking what are the chances that you will have two instances of heads in your first two flips out of 6 flips you simply need to do:
\frac{1}{2} * \frac{1}{2}
(50% chance of heads for the first flip) (multiplied) (50% chance of heads for the second flip)
= \frac{1}{4} = 25%
i'm asking, if
{HHTTT} means "first 2 are heads"
then
does
{HHTHH} also mean "first 2 are heads" ?
or does it mean that the rest of the 4 flips must all be tails ?
zeion, if we are to interpret what it says from your paraphrasing - and you don't know what it means, how are we to give the correct interpretation?
Write out the question exactly.
Suppose that we flip a coin six times and roll a 6-sided die once. Suppose also that all outcomes of this experiment (consisting of an ordered sequence of results for the flips (heads of tails) and the number showing on the die after the roll (an integer from 1 to 6)) are equally likely.
Find the following probabilities:
1) .. i am done
2) The probability that the first R flips are heads, where R is whatever number is showing on the die.
3) ..
4) ..
Ok so,
-if the die shows a 2, what is the probability that the first 2 coin flips are heads?
and
-if the die shows a 5, what is the probability that the first 5 coin flips are heads?
and
-etc.
so I am asking:
what does it mean first 2 coins are heads?
Is it {HHTTTT} ?
zeion said:
so I am asking:
Is it {HHTTTT} ?
We don't care about the last four flips, so it would be HHXXXX, where X could be H or T.
so probability for first 2 are heads is 2^4 / 2^6 ?
Probability that first two flips are heads is .5 x.5 = .25
oh that is much simpler
so first 2 are heads and roll a 2 is (1/4) * (1/6) = 1/24 ?
I am having trouble parsing that sentence. Can you please be a little more verbose? Caps and punctuation are required by board rules to aid comprehension.
Oh, that is much simpler!
Let A be the event that the dice lands on 2.
Let B be the event that the first 2 flips out of 6 are heads.
Let E be the event that the dice lands on 2 and the first 2 flips out of 6 are heads.
Then,
E = A∩B since A and B are independent.
Then,
P(E) = P(A∩B) = P(A)P(B) = (1/6)(1/4) = 1/24
Does that look right?
