How Does Phase Space Differ from Real Space in Dynamics?
In summary: In real space, we can only see one moment in time, but in phase space, we can see how the system evolves over time. This is because all the necessary information about the system is contained in the phase space variables, rather than just the spatial coordinates. In summary, phase space is a mathematical tool that represents all possible system configurations, and dynamics occur in this space rather than in real space.
aniket7tomar
What exactly is phase space and how is it different from real space i.e. 3 co-ordinate system?
what does it mean when someone says "dynamics occurs in phase space"?
I'm very new to all this so pls take that into account to
Yes, i did but i could not get a feel of it...i mean I'm not able to put it in perspective with real world the way I'm able to do with 3 co-ord. system...
I also tried looking at the "space" page of wikipedia but could not understand it either...
Tnx
Drop this intuition completely. Do not compare the phase space to the physical space. They are completely different concepts.
Phase space is a mathematical tool. It's a set of all possible system configurations. You can say, the set of all possible universes. A point in this space is a one particular universe at one moment of time. The metric in the phase space says how similar two universes are.
Likes 1 person
The phase space is the complete set of variables in a system of differential equations. So if you have 2 differential equations (with two variables total) then you can plot state trajectories on paper using the xy axes. If your system is 3D, then you need x, y, and z axes to represent the phasespace of the system. Its difficult to imagine a 4D system (but still doable with some cleverness).
They are not necessarily spatial variables, but they can be. The point is to analogize the variable space to real space to help our intuition to see how the system behaves. So we can imagine the system as it changes state as a particle moving through space.
Likes 1 person
Have a look at the Wikipedia page on simple harmonic motion. You will get a feel for what a trajectory in phase space is.
Likes 1 person
aniket7tomar said:
okay, now i understand it somewhat...but can you also please tell me what the proffesor in the video means whenhe says "dynamics is not happening in real space but in phase space which is both velocity and co-ordinates" at 19:45
http://www.youtube.com/watch?v=8X1x9RLaaxc&list=PL3E3224DA58C14109
The coordinates of the particles are not sufficient to describe the dynamics of the system, you need also the velocities. In that sense, knowing where the particles are in space doesn't tell you how the system will evolve dynamically. On the other hand, knowing both the position and velocity of the particles, which you could call their coordinates (or "position") in phase space uniquely determines the dynamics of the system. The dynamics of the system is a specific trajectory in phase space.
(Note that this is in a context where all the internal and external forces on the system are known and accounted for.)
He means what he was saying for the last couple of minutes before 19:45. The dynamics of a system are not fully described by the coordinates. Having a position at a given time (x(t_o),y(t_o),z(t_0)) is not enough to determine the position immediately after t_o.You also need momentum
(Px(t_o),Py(t_o),Pz(t_0)). This means that the dynamics happen in a 6D phase space for a single free particle.
For example, if a pendulum is swinging, it passes through theta=0 (straight up and down). But passing through theta=0 from left to right is a different state than passing through theta=0 from right to left. In each case, the velocities are different, so the velocity AND the position are both required to give a full description of the system's state.
Okay, so we say dynamics doesn't occur in real space because all the different states can't be determined for which we'll also need velocities and in that sense physics of stationary objects or statics can occur in real space...
Also saying dynamics doesn't occur in real space and saying that the system concerned is changing positions in real world are both true and not contradictory because they are two completely different things...
Pls tell me if I'm wrong somewhere and tnx for helping out
If you were solving for the motion of n interacting particules using Newton's second law, you would be solving 6n equations in 6n unknowns: 3 spatial coordinates and 3 velocity components for each particle. The 6n is often referred to as the number of "degrees of freedom" of the system. The 6n unknowns are referred to as the phase space variables.
Chet
What exactly is Phase space?
Phase space is a mathematical concept used in the study of dynamical systems. It is a multidimensional space that represents all possible states of a system. Each point in phase space represents a unique state of the system, and the trajectory of the system can be traced by following the movement of these points over time.
How is Phase space different from physical space?
Physical space refers to the three-dimensional space in which we live. Phase space, on the other hand, is an abstract mathematical space that represents the state of a system. It can have any number of dimensions, depending on the number of variables that are needed to describe the system.
What is the significance of Phase space in science?
Phase space is a powerful tool for understanding and predicting the behavior of complex systems. It allows us to visualize and analyze the dynamics of a system, and make predictions about its future behavior. It is used in a wide range of fields, including physics, chemistry, biology, and economics.
How is Phase space related to chaos theory?
Phase space plays a crucial role in chaos theory, which is the study of nonlinear and unpredictable systems. In chaotic systems, small changes in the initial conditions can lead to drastically different outcomes. Phase space helps us visualize these changes and understand how they affect the behavior of a system.
Can Phase space be applied to all types of systems?
Phase space can be applied to any system that can be described by a set of variables. This includes physical systems such as pendulums or planetary orbits, as well as abstract systems such as financial markets or biological populations. However, for highly complex systems, it may be difficult or impossible to accurately represent all possible states in phase space.
  • Quantum Physics
  • Thermodynamics
  • Quantum Interpretations and Foundations
  • Astronomy and Astrophysics
