What Factors Affect the Tension in a String Between Two Sliding Boxes?
  • Thread starter Thread starter faet
    Hill
The discussion focuses on calculating the tension in a string connecting two sliding boxes on a ramp inclined at 41°. Two masses, each 2.00 kg, experience different coefficients of kinetic friction (0.26 for m1 and 0.15 for m2). The acceleration of the system was determined to be 4.91 m/s² using frictional forces and gravitational components. Participants shared their approaches to derive the tension, applying Newton's second law and setting up equations for each mass. The conversation emphasizes the need for clear calculations and the correct application of forces acting on each mass to find the tension in the string.
faet
http://www.cse.sc.edu/~thomps66/cobol/6-34.jpg (for image of boxes)
Two masses of 2.00 kg each, connected by a string, slide down a ramp making an angle of 41° with the horizontal. The coefficient of kinetic friction between m1 and the ramp is 0.26. The coefficient of kinetic friction between m2 and the ramp is 0.15. Find the magnitude of the acceleration of the masses.
I found the acceleration
4.91 m/s^2
What is the tension in the string?
is what I am having trouble with.
You need to show some work. What have you done?
i calculated the accel by using
fk=uk*m*g*cos(theta) on each of the two blocks. adding them then using m*g*sin(theta)-fk=m*a
fk values:
m1 = 3.84
m2 = 2.218
as for tension, i tried to do
f=ma
f=(2)*accel which doesn't work.
m*g (since its kinda hanging)
2*9.8
2*9.8cos(41) (since its at angle and not straight down)
2*9.8sin(41) (same as above but dif angle)
On m1 block you got the tension force, the gravitational force, and the friction force acting!
Applying Newton's 2nd Law
\sum_{i=1}^{n} \vec{F}_{i} = m \vec{a}
On m1
\vec{T} + m_{1} \vec{g} + \vec{F}_{friction}_{1} = m_{1} \vec{a}
On m2
\vec{T} + m_{2} \vec{g} + \vec{F}_{friction}_{2} = m_{2} \vec{a}
\vec{T} = Tension?
Basicly, you have the scalar equations for each body
For the m1
\sum F_{x} = T - \mu m_{1}g \cos \theta + m_{1} g \sin \theta = m_{1} a
For the m2
\sum F_{x} = m_{2} g \sin \theta - T - \mu m_{2}g \cos \theta = m_{2} a
