What force is needed to prevent a plane from crashing?
  • Thread starter Thread starter Bonjkk
    Force
To prevent a plane in freefall from crashing, a significant force is required to decelerate it from its speed of 1200 km/h to a stop. The discussion highlights the mass of the plane (20,000 kg) and the person attempting to hold it (50 kg), emphasizing the substantial difference in mass. The initial approach of using the formula M x G was deemed incorrect, indicating a need for a more complex calculation involving deceleration. The importance of deceleration is stressed, as failing to do so would result in a crash at high speed. Understanding the physics of force and motion is crucial in determining the necessary force to stabilize the plane.
Bonjkk
A plane is in a freefall heading downwards and is about to crash
how much force does it require for a person to hold the plane from the nose of the plane and level it down so it does not crash.
Masses
Humen 50kg
plane 20,000kg
vi: 1200 km/hr
question i want to know is how much for does it take for a person that weighs that much to stop a falling plane.
i tried to do M x G but apparently it is not correct.
any help would be appreciated thanks.
The plane is moving... You'll need to decelerate it from 1200kmh to 0.
the plane is falling why do i have to decelerate it?
Well, if you don't decelerate it before it reaches the ground, it'll crash onto the ground at 1200 kmh.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
