What fraction of light is reflected from the air water interface?
The discussion centers on calculating the fraction of light reflected at the air-water interface using the reflection coefficient formula R = ((n2 - n1) / (n1 + n2))^2, with n1 = 1 and n2 = 1.33. Initial calculations suggest that approximately 25% of light is reflected, but some participants argue that the correct reflection coefficient is closer to 2%, based on their calculations. Discrepancies arise from miscalculations, particularly in the denominator, leading to confusion about the correct values. Ultimately, the consensus is that about 2% of light is reflected, while 98% is transmitted. Accurate interpretation of the reflection coefficient is crucial for understanding light intensity reflections from bodies of water.
stunner5000pt
What fraction of light is reflected from the air water interface? i.e. How intense is your reflection from a lake?
since the reflection coefficient is R = (\frac{n_{2} - n_{1}}{n_{1} + n_{2}})^2
n1 = 1 and n2 = 1.33 so R = 0.248. I am not sure how to interprete this?
25% of the light reflects?? is that the appropriate answer?
Yes. 25% is reflected. 75% is transmitted (refracted).
EDIT: Check your calculation. I get R=0.02, So 2% is reflected.
so th fraction would be 1/4 right? Thanks for the help!
I get R=0.02
As did I. R = .02
i think you are forgetting to square it it's (0.33/1.33)^2 = 0.062
Nope.
(\frac{1.33-1}{1 + 1.33}) = .1416...
.1416309^2 = .020059...
I don't see the problem.
EDIT: You divided by the wrong number...it's 2.33 not 1.33
