I What happens in the area between black holes before they collide
tflahive
TL;DR Summary
The area between two black holes before they collide must be under a great deal of stress. That stress change should be measurable by the effect of radiation or light coming through that area.
Recently there have been a lot of studies of black holes colliding and the gravitational waves that they produce. My question is: What is the effect on the space between the two black holes before they collide. The stress must be extraordinary. That stress should be measurable by radiation, or light coming through that area.
It's empty space, not very different from the empty space close to the horizon of a single black hole.
What stress are you talking about? What kind of stress do you think empty space can have?
Likes Dr.AbeNikIanEdL
You could certainly calculate the expected path of light from a source beyond the black holes passing between them. It would have to be a numerical calculation, as no analytical solution is known for colliding black holes.
However, I don't think there's an awful lot of point. We aren't aware of any nearby black hole pairs in the late stages of an inspiral, so there's no way to test the results. The ones we've seen with LIGO are too far away, and we only find out about them as they happen - so no time to get a telescope pointed even if it could resolve anything. And, as Peter implies, I don't think anything particularly extraordinary would be expected to happen - light paths will be complicated, but no more than that. We could be wrong about that, I suppose, but the observational difficulties mean we probably can't test this particular scenario anyway.
tflahive said:
Summary:: The area between two black holes before they collide must be under a great deal of stress. That stress change should be measurable by the effect of radiation or light coming through that area.
Despite what a lot of popular science sources suggest, there is no fabric of space to be put under stress. Space itself is vacuum.
Right now you are between two black holes. Feel anything unusual?
  • Haha
Likes DaveC426913, QuantumQuest, berkeman and 1 other person
The black holes I'm between are not about to collide anytime soon, how about you?
How soon is soon?
Wondering what type of black hole(s)?
Super massive black hole with a baseball size hole.
Not answering, just wondering.
If a proton happened by chance to be at the point of merger, which hole would it fall into first?
As long as GR holds up, it doesn't make any difference. There's nothing unusual about spacetime near black holes aside from the degree of curvature. For a sufficiently small (microscopic) hole I think we do eventually have to worry about quantum gravity, but since we don't have a working theory of quantum gravity we can't say much about that.
Once the holes touch they are one hole, so this question isn't really answerable. Black holes are vacuum solutions, so you can't really imagine painting one red and one blue and describing parts of the combined hole as having come from the red one or the blue one.
So no spagetification of one black hole to another.
Sorry. Had to throw that in.
It is one of the numerous questions of black holes.
Thanks.
And even that can be small if the holes are large enough.
Likes Ibix
Well, I'd expect each horizon to be deformed towards the other. It's just that once they touch you don't have two separate horizons, and they aren't made of matter so it's a bit difficult to find anything you can point to and say "this used to be part of the small/large hole" in any way that isn't completely arbitrary.
Likes 256bits
Moderator's note: Thread level changed to "I".
The tidal forces would be quite high for ordinary black hole mergers in the range we have detected so far. That isn’t exactly an effect on space, but certainly on any matter in the area.
I think in the moment they touch the resulting black hole is highly deformed, is radiating violently gravitational waves away and that then there exists only one singularity compared to the moment before.
In the sense that the intersection of the horizon with a surface of constant "time" in the coordinates usually used is not spherical, but shaped more like a dumbbell, yes.
Yes.
No. There is only one singularity. As far as spacetime is concerned, there is only one horizon too; it is just shaped like a pair of trousers instead of like a cylinder (speaking heuristically). What we normally describe as two black holes merging is just the legs of the trousers coming together; but in spacetime, the trousers are still one surface, not two.
Likes Orodruin
With the legs of the trousers being tightly twisted (but not touching each other) near the crotch.
Dale said:
With the legs of the trousers being tightly twisted near the crotch.
Yes.
My remark refers to the moment "before they touch". Do you describe this moment?
I described the 4-dimensional spacetime geometry. There are no "moments" in what I described; I described the global properties of the geometry. The fact that there is only one horizon and one singularity is a global property of the geometry.
Can one draw a Penrose diagram, or something analogous to a Kruskal diagram, for colliding black holes?
I have been interpreting the trousers such that there is this "moment" and that there exist two separate black holes before this moment each with its singularity. But this is a misunderstanding if I understand you correctly.
I have not seen one. The problem is that these diagrams require spherical symmetry so that two of the four dimensions can be suppressed. A spacetime with two black holes in it is not spherically symmetric. It is not even axially symmetric; in the general case it has no Killing vector fields at all, at least not globally (there may be approximate axial and timelike KVFs in the far future).
Likes Ibix
It's not a misunderstanding so much as a use of vague ordinary language. What does "two black holes" mean?
If it means "the intersection of the horizon with a surface of constant time in my chosen coordinates is two disjoint 2-surfaces for times before some particular time in my coordinates", then in that sense, you can say there are two black holes before a certain time.
But if it means "there are two disjoint regions of spacetime which can't send light signals to infinity", then in that sense it is simply false; there is only one such region, and it is the one I described, shaped like a pair of trousers.
If you are looking at singularities, the only meaning of "black hole" that is relevant is the second one--singularities are "attached" to regions of spacetime, not coordinate choices. So there is no valid viewpoint according to which there are two singularities before some particular time and one after. There is just one.
Likes mfb and timmdeeg
Thanks that gave me a new insight.
If the two black holes are colliding without matter nearby, no, there won't be any visible radiation at all. However, if there is matter there, it's definitely conceivable that there will be some interesting effects present. My thought, however, is that the space between two black holes would be less curved rather than more, because the gravity of the two black holes would partially cancel in that regime.
It definitely is an interesting question to me what would happen if two black holes with active accretion disks were to collide, and the answer is sure to be rather difficult to determine in precise terms due to the complexity of the systems. But interesting nonetheless.
The "acceleration due to gravity" due to the two holes might partially cancel, but that is not spacetime curvature. Spacetime curvature will, if anything, be larger in between two black holes than it would be due to either hole individually. But really spacetime curvature is a tensor and doesn't have a single "size".
As the SET is identical zero in this scenario do we talk about Weyl curvature then? And would a ball of test particles increasingly be distorted such that the long axis of the ellipsoid coincides with the straight line connecting the two black holes?
Yes.
To a first approximation, yes, at least for the case where the holes were large enough and far enough apart that linearly superposing the curvatures from the two holes was a good first approximation. But no exact solution is known for this case, and the EFE is nonlinear so as the holes get closer the actual curvature is more and more poorly approximated by a linear superposition of the individual solutions for each hole.
Likes Dale and timmdeeg
  • #31
PeterDonis said:
Yes.
Thanks.
  • #32
I mean that the area, and what ever is in that area, between two gravity wells must be pulled in two directions.
  • #33
Well - the net "pull" (not a great term in the case of general relativity, which doesn't model gravity as a force) will always be in one direction or another. It is the result of the combination of the gravitational effects of both holes, though, yes. But that isn't anything particularly special - you are being "pulled on" by the Earth, Sun and Moon right now.
  • #34
You can use the Ricci scalar for a coordinate-free description of the total amount of space-time curvature. Obviously this doesn't tell you all of the details of the curvature, but I think it's a reasonable way to make this situation more concrete.
But I guess it makes sense that the space there would be highly curved, for the reason that a small amount of movement towards either black hole will have a large impact on the future trajectory of a particle.
  • #35
Not in a vacuum spacetime, which is what we're talking about (black holes are vacuum solutions); the Ricci tensor is identically zero in vacuum.
The Kretzschmann scalar would be the nonzero one to use in this case.
Likes kimbyd and Orodruin
  • #36
Just to point out that this is not necessarily true, as it has been mentioned a couple of times in this thread. The Reissner-Nordström metric describes a charged black hole and such a black hole comes with a non-zero electromagnetic field and therefore a non-zero energy-momentum tensor.
  • #37
Yes, that's a valid point; but the stress-energy tensor for this case is traceless, so the Ricci scalar is still zero.
  • #38
I would agree if you talk about an extended area and if this extended area is placed such that a point within this area is halfway between the two holes , see post #29. Another question is if it makes sense to say that a point (in contrast to an area) is being pulled in different directions.
  • #39
First you need to specify what you mean by "pull". As @Ibix has pointed out, gravity is not a force in GR so there is no "pull" in the Newtonian sense.
  • #40
"pull" in the sense of what happens to a "ball of test particles" as mentioned in post #29, so no forces.
  • #41
Ok, then "pull" is a bad term to use since, as you say, there are no forces and all of the test particles are in free fall. The correct term for what happens to the test particles is "tidal gravity". And any given ball of test particles will have one thing happen to it, so it makes no sense to say it has two "pulls" on it.
Likes timmdeeg
  • #42
Either way, after looking into the matter, I'm pretty sure the Ricci scalar wouldn't provide much of any information about the curvature caused by the black holes themselves, even in the non-idealized scenarios. There may be some higher-order effects, but it seems like most* of the information about the situation will be suppressed. Most of the source for the Ricci scalar, if any, would stem from matter in the area around the black holes.
* The only reason why the contribution to the Ricci scalar from the black holes might be non-zero would be due to the fact that GR isn't linear, and thus solutions to the field equations don't simply add together.
  • #43
For an uncharged black hole, which is a vacuum solution, the Ricci scalar is always identically zero.
For a charged black hole, with no other stress-energy present, the SET of the EM field due to the hole's charge is traceless, so again the Ricci scalar is zero.
These statements are true even for solutions with multiple black holes present, because they don't depend on any symmetry of the solution or on a linear approximation when superposing solutions. They depend only on the definition of "vacuum" and the known properties of the SET of any EM field.
  • #44
That's why I said that the primary source for the Ricci scalar would be matter around the black holes, and any contribution from the black holes (if there is any) would stem from non-linear effects.
  • #45
And my point is that there is not any contribution from the black holes due to non-linear effects. There can't be, because the two statements I made (vacuum = zero SET = zero Ricci scalar, EM = traceless SET = zero Ricci scalar) are true for any black hole solution whatever, non-linear effects and all.
  • #46
Put slightly differently:
Take the trace of the EFEs. You now have a linear relationship between the Ricci scalar and the trace of the stress-energy tensor. This is independent of non-linear effects from the black holes. If the SET (or less restricted, its trace) is zero locally, then so is the Ricci scalar.
  • #47
Agreed, I was actually referring to the term "pull" with regard to the comment "I mean that the area, and what ever is in that area, between two gravity wells must be pulled in two directions", #32.
Do you agree that depending on whether or not this area is occupied by a body (being hold together by e.g. intermolecular forces) one should talk about tidal acceleration or tidal forces respectively. The term "tidal gravity" doesn't seem to distinguish between tidal acceleration and tidal forces. But please correct if wrong.
  • #48
I do not agree. Since there is no gravitational force there can be no tidal force, which in Newtonian gravity are due to differences in gravitational acceleration. Instead, tidal gravity (as Peter mentions) or ”geodesic deviation” is the more appropriate description. For an object that is held together, different parts of the object will deviate from the geodesics due to internal forces. Those forces are exactly that, internal, and not tidal forces. Just as what is preventing you from falling through the surface of the Earth is an electrostatic force between you and the surface, not a gravitational force.
Likes timmdeeg
  • #49
Thanks, I hope I understand you correctly.
So ”tidal gravity” is tantamount to ”geodesic deviation”. Both terms refer to test particles in free fall and thus to geodesics.
I thought the term "tidal acceleration" is restricted to particles on geodesics, e.g. the ball of test particles mentioned above and the term "tidal forces" to particles not on geodesics, e.g. those hold together by cohesive forces.
But what exactly distinguishes tidal gravity from tidal acceleration?
  • #50
Choice of terminology. What you are calling "tidal acceleration" is the same thing as what @Orodruin is calling "tidal gravity" or "geodesic deviation". His terms are the more usual ones in the literature.
No; as @Orodruin said, there are no such things as "tidal forces". The forces experienced by particles not traveling on geodesics when tidal gravity is present do not come from tidal gravity; they come from non-gravitational interactions between the particles in a bound object, which prevent the particles (or at least those not at the center of mass of the object) from traveling on geodesics.
