What happens to a pump's pressure gauge if you disconnect a hose line
When a hoseline is disconnected from a pump, the pressure gauge typically reflects the static or deadhead pressure of the pump rather than dropping to zero. This is because the gauge measures the pressure in the system, which can increase due to the removal of resistance. The flow rate may increase as a result of the disconnection, but this can lead to a decrease in pressure depending on the pump type and conditions. It's important to refer to manufacturer charts for specific pump performance under varying conditions. Overall, the dynamics of pressure and flow are influenced by the pump's characteristics and the system's configuration.
David43214
New user has been reminded not to try to use AI chatbots as references in the PF technical forums
TL;DR Summary
Would the pressure go up or down?
Imagine a firetruck with a hoseline attached to the pump. The pump is set to 800kpa with 100kpa loss due to friction in the 30m hoseline so you have 700kpa at the nozzle.
What would the pump's gauge read if you disconnected the hoseline?
I thought since there is no more resistance, the pressure gauge would show a much lower reading, maybe 0 because the pump's outlet is now at atmospheric pressure.
However, ChatGPT was telling me the gauge jumps to the static (deadhead) pressure of the pump.
I believe that you are correct: the gauge pressure would go down, while the waterflow would increase.
A chart for that particular pump should tell you what the manufacturer has recorded from the tests completed for different conditions.
Welcome to PF.
Please keep in mind that AI chatbots are not considered valid references in the technical PF forums. Thanks.
Likes sophiecentaur
Will the flow increase or decrease?
If the flow increases, does that mean the pressure falls?
Does it depend on the type of pump being used?
Does removal of the hose and nozzle restriction, connect the pump output with the gauge, directly to atmospheric pressure?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
12K
