Where Does the Charge Go When Connected to a Grounded Capacitor?
  • Thread starter Thread starter Nanoath
    Charge
When a charged object is connected to a grounded capacitor, the charge of the object decreases as it transfers some of its charge to the capacitor, which initially was uncharged. The capacitor's plate acquires the same charge as the object, while the grounded side of the capacitor draws an equal but opposite charge from the ground. This creates a potential difference between the capacitor plates, allowing energy to be stored. Electrons cannot move between the plates due to the insulating material separating them. Charge does not disappear in a local system; it is redistributed between the charged object and the capacitor.
Nanoath
What happens to a charged object, it can be anything, when it's connected to a capacitor, and the other side of the capacitor is grounded.
Does the charge disappear?
No. When the charged object is connected to the capacitor(plate), the charge of the object will reduce as much as the charge increases in the capacitor (if the capacitor was uncharged before). In other words the capacitor(plate) will get the same charge as the object. (Both have either + or - charge). Since the other "side" of the capacitor is connected to the ground, an equal, yet opposite charge will "emerge" from the ground to the other plate. There is now a potential difference between the plates due to the charge differences of the plates, and thus energy is stored. Electrons cannot travel from one plate to the other because of the insulating material between them.
Charge never just "disappears" (in a local system).
This is my guess... You might want to check with somebody whose smarter than me...
Just to make it clear. You move the charged object from the capacitor after it has given part of its charge to the plate? So they don't stay connected.
Right.
Careful, Ofey -- the charged object and the capacitor plate will eventually reach the same electric potential, not the same charge. C=\frac{Q}{V}.
Appreciate the correction
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
