What Happens When Steam and Water Reach Thermal Equilibrium?
The discussion revolves around a thermodynamics problem involving the thermal equilibrium of steam and water. Participants explore concepts related to energy conservation, specific heat capacities, and entropy changes in a closed system.
  • Homework-related
  • One participant poses a question about the outcome of mixing steam and water at different temperatures and asks for help with calculations regarding thermal equilibrium.
  • Another participant suggests that the total energy of the system must remain constant and proposes equating the specific heat capacity equations for steam and water to find the final temperature.
  • A different participant expresses uncertainty about how to proceed with the derived ratio of temperature changes between steam and water.
Participants do not appear to reach a consensus on the methods to solve the problem, and multiple approaches are suggested without resolution.
There are unresolved assumptions regarding the specific heat capacities and the latent heat of evaporation, as well as the conditions under which thermal equilibrium is achieved.
This discussion may be useful for students or individuals interested in thermodynamics, particularly those studying heat transfer and phase changes in fluids.
Crocodile
Hi
Just wondering if I could have a bit of help on this question. Thanks in advance!
3) 100 g of steam at 150_C and 1 kg of water at 20_C are placed together inside
an insulated volume. The specic heat of steam is 2.02x10^3J kg_1K_1, that
of water is 4.19 x10^3 J kg_1K_1 and the latent heat of evaporation of water is
226x10^6 J kg_1.
a) Once the two fluids have come into thermal equilibrium what is left - water or
steam?
b) Calculate the final temperature of the system.
c) Is the net change in the internal energy of the system positive, negative or
zero?
d) Calculate the increase in entropy of the system.
Science news on Phys.org
Welcome to PF!
Hi Crocodile! Welcome to PF! :smile:
Yes, but only a bit :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Thanks for the welcome! Well...sorry to sound slightly stupid, but this topic isn't my forte so I haven't really got a clue where to start! Any help at all would be appreciated.
Well, for part b I may have an idea - whether its viable or not I'm not sure... My thoughts are that we know that the total energy of the system must remain constant. Therefore would it be possible to put the specific heat capacity equation of both cases equal to each other? I.e. the dQ would be the same for both the steam and the water.
Thanks.
Crocodile said:
Well, for part b … we know that the total energy of the system must remain constant. Therefore would it be possible to put the specific heat capacity equation of both cases equal to each other? I.e. the dQ would be the same for both the steam and the water.
Essentially, yes …
write out the equation and see what you get. :smile:
Right, so now I have a ratio of the two dT's - between steam and water. Is that correct? I'm not sure how to use this though... Sorry if this is an elementary question and I'm just being slow!
10K
  • · Replies 19 ·
15K
