What have I done wrong? (projectile motion)
The discussion revolves around a physics problem involving projectile motion, where a cricketer needs to throw a ball 80 meters to a wicket keeper at a speed of 140 km/hr. The main challenge is determining the correct angle of projection to ensure the ball reaches the wicket keeper without hitting the ground. Participants suggest using the vertical component of the throw and the time of flight to solve for the angle, with some confusion about the calculations leading to the value of 38.9 m/s as the initial velocity. The conversation emphasizes the importance of considering the heights of both players and applying the range formula to find the angle needed for the throw. The thread highlights the complexities of projectile motion and the need for precise calculations to achieve the desired outcome.
Mayzu
A cricketer fields the ball in the outfield, some 80 meters from the wicket keeper. The fielder needs to return the ball to the wicket keeper as quickly as possible. He can throw the ball with a speed of 140 km/hr. The cricket ball has a mass of 0.0168kg
(e) The fielder decides to throw the ball straight back to the wicket keeper, 80 m away. At what angle to the horizontal must he project the ball so that the ball reaches the wicket keeper without hitting the ground?
This question is worth 8 marks, but I cannot figure out how to do it!
Vf=Vi+a(delta)t
http://imgur.com/OJEDalz
^here's my working out. I just can't get past the last step, and my graphics calculator can't either, making me think I'm doing it completely wrong.
Vf=Vi+a(delta)t
Where does the number 38.9 come from in your work?
I think the right approach is to key in on Vy=0 at 40m, and use the time from that equation to help the rest of your calculations...
38.9 is the initial velocity of the ball. That's what I've done, but I'm stuck...
Vf=Vi+a(delta)t
Are both of them (the players) assumed to be just two points? Shouldn't their heights be taken into account? In that case, you could use 38.9 as initial velocity (resultant) and put that in the range formula to get sin2θ. That value of θ would be the critical one, means just enough to make the ball reach the ground.
Vf=Vi+a(delta)t
If your calculations are right so far, you're just a step away from the answer. sin2θ is 2sinθcosθ..
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
