What Holds People on Earth if Gravity is the Spacetime Fabric?
  • Thread starter Thread starter Nickriener
    Earth Spacetime
Gravity is described as a distortion of spacetime caused by mass, with both the Earth and the Sun influencing this "fabric." The Earth pulls on spacetime just like the Sun, which is why people remain anchored to the Earth's surface. The strength of gravity is determined by the mass of an object, meaning all mass affects spacetime. This leads to the conclusion that spacetime is indeed a property of mass. Understanding these interactions clarifies how gravity operates on Earth and throughout the universe.
Nickriener
Ok, so according to Einstein, the Earth is held in by a "fabric" due the the Sun pulling on said "fabric." So my question, what holds people on Earth if gravity is this "spacetime fabric?"
Astronomy news on Phys.org
Hi Nickriener! :smile:
Nickriener said:
what holds people on Earth … ?
the Earth also pulls on the fabric. :wink:
not only Sun, every objects will pull on the fabric...Earth also unexceptional..so it depends on the size of the object to determine the strength of the gravity..
All mass distorts what you call “ space-time fabric”
good point gear300
vibjwb said:
All mass has what you call “ space-time fabric”
So that means space-time is also a property of mass?
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
