Torog
- 53
- 1
How do we decide what is a clock and how do clocks that rely on different technologies stay synchronized?
The discussion revolves around the definition of clocks and the synchronization of different clock technologies. Participants explore the nature of clocks, the criteria for synchronization, and the underlying mechanisms that contribute to the stability of various types of clocks.
Participants do not reach a consensus on the definitions and criteria for what constitutes a clock or the mechanisms that ensure their stability. Multiple competing views and uncertainties remain throughout the discussion.
Some discussions involve assumptions about relativistic effects and the arbitrary nature of time definitions, which are not resolved. The relationship between mass and clock stability remains unclear, with differing opinions on its relevance.
Torog said:How do we decide what is a clock
DrStupid said:If the output of two or more devices comply with Einstein's clock synchronisation, the devices are a clocks and their output is a measure of time.
Torog said:How do we decide what is a clock and how do clocks that rely on different technologies stay synchronized?
PeterDonis said:Two clocks in relative motion in flat spacetime don't meet the condition, but that does not mean they can't be considered clocks.
First you use each clock to establish a length standard usable when that clock is at rest (for example, the meter is the distance traveled by light in 1/299792458 second, using the cesium clock definition of the second). Then you calculate the proper time between two consecutive readings of one clock using that clock and the other clock. If these calculations agree to the limits of your measurement accuracy then they are good clocks.DrStupid said:Yes, they can be clocks. But how do you check that?
https://en.m.wikipedia.org/wiki/Caesium_standardTorog said:I have a lovely pendulum clock on my wall. It is accurate to within a minute a week. The speed of the clock is regulated by the equivalence of inertial mass and gravitational mass. What about the other clocks? What do they depend on to be stable (lets assume we are not traveling at enormous speeds and we are all in the same gravitational field).
The "travelling at enormous speeds" part of this question is a red herring that you would do well to let go of. Everything is traveling at enormous speeds relative to something somewhere. For example, your pendulum clock works just fine (in the sense that I described in #9 above and to the limits of its accuracy) whether you or someone on Mars watching through a telescope and moving at a few kilometers per second relative to it is depending on it to measure time.Torog said:What do they depend on to be stable (lets assume we are not traveling at enormous speeds and we are all in the same gravitational field).
russ_watters said:https://en.m.wikipedia.org/wiki/Caesium_standard
Why do I feel like I'm providing research for a paper?
No, weight/mass have nothing to do with the operation of an atomic clock.Torog said:Does the inertial weight of the bits of the cesium atom provide stability to the atomic clock?
russ_watters said:Physicists seem to use the circular definitions:
-Clocks are devices that tell time.
-Time is what a clock measures.
From: http://hyperphysics.phy-astr.gsu.edu/hbase/Nuclear/nspin.html#c1russ_watters said:No, weight/mass have nothing to do with the operation of an atomic clock.
I don't know. I'm pretty thin on QM. What does this have to do with the topic?Torog said:Surely the Spin or angular momentum - inertia - is an integral part of the mechanism to the hyperfine structure of the nucleus.
I think what @russ_watters was getting at is the ratio of weight to mass (weight/mass) has nothing to do with atomic clocks, which is correct. Certainly the mass of the particles involved will effect the transition frequencies in an atomic clock. Current theory is these masses are fixed.Torog said:Surely the Spin or angular momentum - inertia - is an integral part of the mechanism to the hyperfine structure of the nucleus.
russ_watters said:I don't know. I'm pretty thin on QM. What does this have to do with the topic?
Torog said:The question is: What is it that stabilizes the clock rate? And does the inertial weight/mass of the bits form part of the stabilizing mechanism?
As I understand the mechanism, the energy requirement to make the hyperfine transition is quite precise. One tunes a microwave beam accurately to maximize the rate at which the hyperfine transition is made and uses the associated frequency as the basis for a clock.Torog said:The question is: What is it that stabilizes the clock rate? And does the inertial weight/mass of the bits form part of the stabilizing mechanism?
What would you consider to be an acceptable answer? You say earlier that the equivalence of gravitational and inertial mass stabilises your pendulum clock, but you don't justify that statementand I'm not at all sure it's correct. For example, I would think that I could take the clock into zero g, give the pendulum bob an electric charge, place it in a uniform electric field and expect it to work (or at least, I could design a pendulum clock for which that was true - too much metal in an off-the-shelf model). I don't immediately see a reason why it would be any more or less stable operating in an electric or gravitational field.Torog said:The question is: What is it that stabilizes the clock rate?
The Earth is a sort of clock - it rotates at a steady rate. A quartz watch is a sort of clock which vibrates a crystal at a steady rate. These are dissimilar technologies. Are you telling me you can't tell the time of day with a quartz watch?John M said:Devices of a dissimilar technology will not synchronise.
Right: I would say it is a by-definition requirement that a "clock" be capable of synchronizing with other clocks, to within its capable accuracy.Ibix said:The Earth is a sort of clock - it rotates at a steady rate. A quartz watch is a sort of clock which vibrates a crystal at a steady rate. These are dissimilar technologies. Are you telling me you can't tell the time of day with a quartz watch?
russ_watters said:Right: I would say it is a by-definition requirement that a "clock" be capable of synchronizing with other clocks, to within its capable accuracy.
Nor do I...but the way you say it implies you think there should be a difference...?Paul Colby said:I guess I don't see a huge difference between clocks used to measure time being synchronized and rulers used to measure distances maintaining a stable length.
